AirAsia A320 Possibly Missing
Haha really!?
We invested in a LiPo battery fire bag. It comes with some cool oven mitts. Of course if I ever had to use this IRL I'd find it much less funny.
Yup! although I was off on some numbers, 10K is about as low as I would go. Wouldn't want anyone getting my tail number...
Gulfstream
Operational Information Supplement
For GII Through G550 Airplanes
Supplement Number GAC-OIS-01:
Mitigation of Potentially Explosive Devices
Basic Issue
March 15, 2005
Type: Abnormal Procedures
Applicability: All Gulfstream "Large Cabin" Airplanes
OPERATIONAL INFORMATION SUPPLEMENT
GAC-OIS-01 ADVISORY DATA ONLY
GAC-OIS-01 BASIC ISSUE
Page 2 MITIGATION OF POTENTIALLY EXPLOSIVE DEVICES Mar 15/05
SECTION 3: ABNORMAL PROCEDURES
Add the following abnormal procedure:
1. Move the device to the airplane’s right forward cabin window.
2. If possible, attempt to secure the device as close to the window
as possible, using tape or any other means available.
3. Remove any portable oxygen, or other equipment that could
become a projectile, away from the area.
4. Cover the device with cushioning materials including but not
limited to clothing, cushions, followed by dry and wet blankets.
5. Move all passengers to the rear of the airplane and ensure their
seatbelts are securely fastened.
6. Descend to as low an altitude as practical.
7. Depressurize the airplane as soon as possible after descent.
8. Notify ATC and request assistance from appropriate agency.
Consideration should be given to the possibility of throwing
the device overboard through the baggage door. If the crew
decides to do this, the airplane should be flown to an area that
is sparsely populated and:
1. Descend to 2,000 ft AGL or lower.
2. Verify that the airplane is depressurized.
3. Extend the flaps to 20 degrees.
4. Move the device to the baggage compartment.
5. Slow to 150 KCAS.
6. Open the baggage door.
7. Throw the device out using a strong downward and aft motion.
Once the device is overboard, return the airplane to the
normal configuration and either continue to the original
destination
or divert to the nearest suitable airport and report
the event to the authorities.
I would estimate 1/3 of the pilots I know couldn't tell you about satellite vs radar returns. At my regional I would show an FO a satellite while headed to Mexico and get a deer in headlights look. Similarly now going towards the Caribbean guys are virtually unaware of the different satellite images available and how to read them.
Or how to read a skew-t, a high altitude wx chart, the difference between vis and IR satellite images, etc. No one takes weather, and aviation wx is usually limited to reading a METAR, TAF and maybe an FA. Oh and we need to make sure you know the different types of fog and how they form.
Indonesian officials report sonar has found the wreckage in "tens of meters of water".
Hopefully the shallow depth will provide quick recovery of remains and the FDR/CVR.
http://www.cnn.com/2014/12/30/world/asia/airasia-missing-plane/index.html
Indonesian searchers say sonar equipment has detected wreckage from AirAsia Flight QZ8501 at the bottom of the sea, a day after the first signs of debris were spotted.
It's still unclear whether the aircraft is in one piece or broken up, said Hernato, a search and rescue official who goes by one name.
This happened yesterday...
This. Holy crap this.
I'm studying for the IR written, and I have to say that while the weather focus is considerably greater than it was for the PPL, I still find myself somewhat slowed down and scratching my head about how to correlate a lot of the weather products I'm being exposed to. I suspect it's the same for many others. For example, I can see what a chart is telling me, and I can read a legend and say, "Hmm, it appears that there is an unstable lapse rate here" but how to translate that into flying conditions is not as clear-cut, nor as clearly taught.
I know that is because weather can be unpredictable despite our best efforts, and that much weather experience comes from...well...experience...but...yeah. I'd love to have scenario-based weather training.
@surreal1221 - you may have an untapped educational market here...
I was a weather forecaster in the Air Force for 12 years. I definitely think that pilots in general could work on their weather smarts. More importantly I think is for pilots to never stop learning about weather.
In my 12 years there was never a day I went into work thinking I knew everything..I was always learning about my primary profession.
I saw a lot of aircrews take their knowledge for granted and never worked on expanding their horizons.
A little knowledge goes a long way...a desire to learn goes even further.
Does the door operate electronically or do you physically have to open it? I wouldn't want to be the one inside having to open that thing.
You've kind of hit the point. You can be all uber cool and know to read some obscure weather chart or know all the symbols on the high altitude prog charts but none of it does a lick bit of good when the wind is 10 knots off the forecast or the temp is colder or warmer than forecast. If there was any precision to this you we wouldn't see AIRMET Tangos that cover 5 states, from the surface to 38000 feet for mod turb and then fly through it and narey a bump is felt.
HOLLY EFFIN ES! You weren't kidding. Imagine if you did it over an area and started a huge fire.
"Err-budy to the back. I'm throwin this crap out! Oh, hold muh beer."
I've been a pilot since 1972, I was a carpenter for 13 years following the PATCO strike. That my friend is a piece of lumber.
I heard a new report saying they can see the shadow of the plane under water from the air.
I can think of multiple parts of many aircraft that looks like. I have a PPL but I don't own a Bellanca, I also have had my A/P since 1993 and spent alot of time disassembling and reassembling turbine powered aircraft. If I were to speculate, which I'm not, I would suggest that that piece might be a portion of the cabin ducting for air conditioning. Composites float too.
http://www.bbc.com/news/world-asia-30875973
"The recording appeared to indicate that the pilot was too busy attempting to regain control of the aircraft to send a distress signal, he said."
For an airplane that has all sorts of "protections" built in, there sure are a lot of loss of control accidents involving Airbus vs. Boeing.
Asiana Airlines was found to have a strong culture of automation to the point their pilots were afraid of manual flight. I'm willing to bet the same will be true with AirAsia.
"'The plane suddenly went up at a speed above the normal limit that it was able to climb to. Then it stalled.'
Rescue team members walk as they carry the wreckage of a seat of the AirAsia Flight QZ8501 airliner …
Earlier at a parliamentary hearing, he said radar data showed the Airbus A320-200 appeared at one point to be climbing at a rate of 6,000 feet (1,800 metres) a minute before the crash. There were several other planes in the area at the time.
'I think it is rare even for a fighter jet to be able to climb 6,000 feet per minute," he said. "For a commercial flight, climbing around 1,000 to 2,000 (feet) is maybe already considered extraordinary, because it is not meant to climb that fast.'"
:ooh:
:ooh:
Can severe storms cause updrafts that would result in that rate of climb?
