AirAsia A320 Possibly Missing
On the deck for the flight control check although the sidestick manipulates full deflections for the equivalent of direct law, it's actually still considered "Normal Law - Ground mode."
I doubt the Air Asia lost all electrical power or lost all 2 ELAC / 3 SEC / 2 FAC at the same time to go into mechanical backup. What I really want to know is what stopped them from going into high AOA protection of A.FLOOR / TOGA LK. If they stalled they were probably at least in alternate law - like AF447.
Full up, full down...
And a load factor demand doesn't make much sense at rotation to me either.
At rotation you're still Normal Law - Ground mode. As soon as weight off wheels, it starts to blend and transitions into Flight mode with RA > 50 ft. Then load factor demand since you are then "Normal law - flight mode."
Weeeeeeeeeeeell, that's largely semantics and largely depends on how your training program teaches it.
You're both right, technically but at the end of the day, does Uber really need an umlaut?
Speaking of Uber, I landed in LAS for an overnight and upon opening the app a message popped up that said Uber was banned from Nevada! ????????????? A state that allows prostitution and gambling but outlaws Uber?
That's right!
Hilarious, isn't it.
Fascinating info. I can kind of see why Airbus built these systems, but I can't help to think of the old saying "When you try to idiot-proof something, they go and build a better idiot."
I heard it as, "You cannot make anything foolproof because fools are so ingenious."
"I wonder what would happen if we did this..."
I'm not sure if you're on the bus or not, but we were told a story of a captain at a different airline that started turning off a couple ADIRU's to see what alternate law felt like. Or direct. I don't know.
There's always one of those.
"If you pull the N1 tach - will that autothrottle respond ...?"
End result: one passenger sucked out of plane to his death.
LOL. Wait. What!?
From Air Disaster Volume 1
Chapter 13 - "If you pull the N1 tach - will that autothrottle respond ...?" National Airlines McDonnell Douglas DC-10-10 November 3, 1973
It was a severe uncontained engine failure with debris impacting the fuselage and tearing a hole big enough to suck one poor soul out of the airplane to his death. They diverted to ABQ and landed safely.
The NTSB expressed concern about the cockpit crew conducting an unauthorized experiment on the auto-throttle system ("...the flight engineer pulled the three N1 tachometer [circuit breakers]...") immediately before the engine exploded. "Regardless of the cause of the high fan speed at the time of the fan failure, the Safety Board is concerned that the flightcrew was, in effect, performing an untested failure analysis on this system. This type of experimentation, without the benefit of training or specific guidelines, should never be performed during passenger flight operations."
You forgot to ask for someone to hold your beer!
You joke but I flew with guys who used to drop beverages on boats as they flew up the Hudson on their way to LGA
"Back in the day..."
This job is definitely not as fun as it used to be!!
"Hey watch this..." or
Sheeeeeeeeeeeeeeeiiii......
