Roger Roger
Bottom of the list
We're VMC, cancel IFR, switching to tower.What?
"local knowledge" that Delta needs, no doubt.![]()
Oh, so by "local knowledge" you mean 'stuff that kills people'.We're VMC, cancel IFR, switching to tower.
CREATING A USER-DEFINED HOLD AT AN ACTIVE FLIGHT PLAN WAYPOINT
1) Press the FPL Key to display the Active Flight Plan Page (MFD) or the Active
Flight Plan Window (PFD).
2) Press the FMS Knob to activate the cursor (not required on the PFD) and
turn the large FMS Knob to highlight the waypoint for the hold.
3) Press the MENU Key, highlight ‘Hold At Wpt’, and press the ENT Key. The
HOLD AT window appears with the course field highlighted.
4) Use the FMS Knobs to edit the entry course, and press the ENT Key.
5) Use the small FMS Knob to select ‘INBOUND’ or ‘OUTBOUND’ course
direction, and press the ENT Key.
6) Use the small FMS Knob to select ‘TIME’ or ‘DIST’ length mode, and press
the ENT Key.
7) Use the FMS Knobs to edit the length, and press the ENT Key.
8) Use the small FMS Knob to select ‘RIGHT’ or ‘LEFT’ turn direction, and
press the ENT Key.
9) Use the FMS Knobs to edit the Expect Further Clearance Time (EFC TIME),
10) Press the ENT Key while ‘LOAD?’ is highlighted to add the hold into the
flight plan.
Garmin G1000 Cockpit Reference Guide for the Piper PA-28-181 Archer 190-01460-00 Rev. A
Yes.Has anyone been ever been issued a non published hold before? Other than training?
Definitely.Has anyone been ever been issued a non published hold before? Other than training?
Frequently.Has anyone been ever been issued a non published hold before? Other than training?
Way more often than getting a published hold.Has anyone been ever been issued a non published hold before? Other than training?
Shoot I had to ask for the published hold at BKA the other day...they told me to hold on my inbound awaiting approach clearance and I was like WTF?Way more often than getting a published hold.
I don't understand. Were you WTF'ing because you were given a hold or because you were given a simple non-published one?Shoot I had to ask for the published hold at BKA the other day...they told me to hold on my inbound awaiting approach clearance and I was like WTF?
The only hold I've been given in more than 20 years (but a lot less hours than you) was a non-published hold. It was to KSAF which is below ABQ radar and I was instructed to hold to wait for departing traffic to clear the area. It was a simple VOR hold on the airway I was already inbound on.In 3k plus hours of part 91 flying I have never been issued a non published hold
Because I was given a non published one at the IAF which has a holding pattern procedure turn. Had I executed their instructions, I would have had to hold unpublished until given approach clearance, then do the entry of the published hold to get set up for final, then shoot the approach. It would have been stupid. As it was I requested the published hold, received it, but slowed down enough that I was given approach clearance just prior to the VOR.I don't understand. Were you WTF'ing because you were given a hold or because you were given a simple non-published one?
That makes sense. Context is everything. I thought it was a situation of, say, holding on the R180 at a IAF/FAF with 360° FAC, not holding on the R300 at the same VOR.Because I was given a non published one at the IAF which has a holding pattern procedure turn. Had I executed their instructions, I would have had to hold unpublished until given approach clearance, then do the entry of the published hold to get set up for final, then shoot the approach. It would have been stupid. As it was I requested the published hold, received it, but slowed down enough that I was given approach clearance just prior to the VOR.
Yeah, my first post was not clear.That makes sense. Context is everything. I thought it was a situation of, say, holding on the R180 at a IAF/FAF with 360° FAC, not holding on the R300 at the same VOR.
