7-9-4. SEPARATION
a. Standard IFR services to IFR aircraft.
b. VFR aircraft must be separated from VFR/IFR aircraft that weigh more than 19,000 pounds and turbojets by no less than:
1. 1 1/2 miles separation, or
2. 500 feet vertical separation, or
NOTE-
Apply the provisions of para 5-5-4, Minima, when wake turbulence separation is required.
3. Visual separation, as specified in para 7-2-1, Visual Separation, para 7-4-2, Vectors for Visual Approach, and para 7-6-7, Sequencing.
NOTE-
Issue wake turbulence cautionary advisories in accordance with para 2-1-20, Wake Turbulence Cautionary Advisories.
c. For the application of Class Bravo airspace separation requirements, the V-22 Osprey must be treated as a fixed-wing aircraft. It is an SRS Category II aircraft but weighs more than 19,000 pounds. The V-22 Osprey must be separated from VFR/IFR aircraft by minimum identified in subparagraph b above.
d. VFR aircraft must be separated from all VFR/IFR aircraft which weigh 19,000 pounds or less by a minimum of:
1. Target resolution, or
NOTE-1. Apply the provisions of para 5-5-4, Minima, when wake turbulence separation is required.
2. Aircraft weighing 19,000 pounds or less include all aircraft in SRS Categories I and II plus G73, STAR, S601, BE30, SW3, B190 and C212.
NOTE-
I can't speak for any of the other idiots but, personally, I thought you asked a very good question and that the Class B example is a good one since it's a class of airspace where ATC takes on responsibility for VFR separation.You guys are all idiots. You can't stick to the simple fact that I was asking a reasonable question which shouldn't have been in the form of an example.
Hey now, I think I resemble that remark...I can't speak for any of the other idiots
I know a wise old guy who would say, "Ask yourself if the operation being proposed is safe, legal, and comfortable, in that order. If the answer to any of the above is 'no,' then it's probably not a good idea."You just don't like the answer (and one where the safe answer and regulatory answer are the same), that the rules on using safety pilots and the rules on "see and avoid" do not depend the airspace you are in and whether ATC has responsibility for separation.
And he has two usernames which is violation of something, somewhere.As an aside to everyone who is reading this thread, and not intending to pick on Caelum that much but as I was a good schoolboy in a Catholic school I couldn't help but raise my eyebrow at his name. Caelum Deus, literally means Chisel God but a more likely connotation probably refers to either 1) the phrase 'caelum et terra' as it appears in the bible, as in 'created the earth' or 2) the Caelum constellation.
With that said I think a fair interpretation of his name is either 'Creator God' or 'SkyGod'. YMMV, but it is an auspicious name either way.
I had a doctor come into my office less than a week ago telling me he read that the FAA had approved flight sim to maintain currency, and wanted to know when I thought it would be approved for ipc's and bfr's.Not sure why he has "caelum Deus" because if he wants to say "sky god" or "god of the sky" it has to be "caeli Deus." Somebody should have studied noun declensions....
Anyway, I keep IFR current at home with Microsoft flight simulator. I heard as long as I log approaches in my local area, the FAA doesn't have a problem with it. So much cheaper, and no need for a safety pilot.
Imagine if a student asked you if they could do solo hood work in class B. What would you say? Would badger them and put them down or would you show them proof of why they cant?
I've always understood "Caelum" to mean "The sky".As an aside to everyone who is reading this thread, and not intending to pick on Caelum that much but as I was a good schoolboy in a Catholic school I couldn't help but raise my eyebrow at his name. Caelum Deus, literally means Chisel God but a more likely connotation probably refers to either 1) the phrase 'caelum et terra' as it appears in the bible, as in 'created the earth' or 2) the Caelum constellation.
You guys are all idiots. You can't stick to the simple fact that I was asking a reasonable question which shouldn't have been in the form of an example. The example wasn't a good one. The question was who has the final responsibility when you're in class b when it comes to traffic separation. That's all. And because a lot of you needed this spelled out this post has gone ass sideways. And continues to go nowhere. I keep questioning why I keep reply, thinking I must have better things to do, but I'm defending my position, and then I think why does everyone else keep responding? You guys must be bored out of your mind
Let me make this all very clear to you *ing idiots because either your childish impulsivity cant resist saying "I cant believe you're a CFI" from one element of what I said, or you have actually read through this entire thread and still cant realize what I'm asking.Reasonable for a new pilot with 5 hours, not so reasonable for an assistant chief with 5000. How many times have you taught see and avoid? That is a day two or three conversation that is pretty easy for them (even the 'idiots') to understand.
Let me make this all very clear to you *ing idiots because either your childish impulsivity cant resist saying "I cant believe you're a CFI" from one element of what I said, or you have actually read through this entire thread and still cant realize what I'm asking.I would ask them if there was anything in the regulations that would cause that to be an issue, and direct them to do their research. If it was a flight instructor asking the question, or even someone with 300 hours and an instrument rating, I'd borderline freak out that they didn't even know the basic regs.
-Fox
Let me make this all very clear to you *ing idiots because either your childish impulsivity cant resist saying "I cant believe you're a CFI" from one element of what I said, or you have actually read through this entire thread and still cant realize what I'm asking.Hey now, I think I resemble that remark...
The operation proposed above is unsafe, illegal, and would make most of us uncomfortable regardless of the first two points, which is why most of the peanut gallery were all "dude, really?"
Tl;dr: "not idiots."
AFIS LINK ACK
Let me make this all very clear to you *ing idiots because either your childish impulsivity cant resist saying "I cant believe you're a CFI" from one element of what I said, or you have actually read through this entire thread and still cant realize what I'm asking.It's all good all you need is the Id 10t forms and schedule a 709 ride with the FAA. In the subject line put "pilot induced blindness".
Let me make this all very clear to you *ing idiots because either your childish impulsivity cant resist saying "I cant believe you're a CFI" from one element of what I said, or you have actually read through this entire thread and still cant realize what I'm asking.This thread is win. That being said, since I used to have an unhealthy fascination with ATC via microsoft flight simulator in my teen years, I will provide my underqualified 2 cents.
While the FAR and AIM both provide more than adequate guidance on this issue from a pilot standpoint, I am often interested in the training literature that ATC gets. This is disseminated mainly through a document called FAA Order JO 7110.65, the relevant section of which is quoted below:
Chapter 7 - Visual, Section 9 - Class B Service Area - Terminal
That seems pretty cut and dry, but in practice has not been what I've always experienced in my very limited time flying Class B transitions. Flying the "Bay Tour" over the top of SFO via their surface area allows very little hand holding for example. You get a terse "Cleared into Class B, remain west of the 101 freeway, maintain VFR at or below 1500." That's it. I found myself with head on traffic at my altitude in that narrow corridor, with very busy controllers who weren't particularly concerned with our immediate affairs, but thanks to see-and-avoid and radio situational awareness it was a non-issue. And I totally don't fault them for that, because they were doing US a huge favor by letting us through. (@ChasenSFO probably knows what I'm talking about.)
So whether or not there's any reg written about it, it's a totally lame move to stop scanning for other traffic in VMC in Class B airspace "because ATC is supposed to be in control." At the end of the day ATC will get a slap on the wrist for being task saturated, and if you miraculously survive your midair and crash, you will be violated for 91.13.
This is beyond the fact that numerous other FARs have already been quoted showing you need a safety pilot any time you're under the hood. All of these thought exercises are fun to find holes in the regs, but at the end of the day if the decisions you make utterly lack common sense as displayed in this thread, they can and will hit you with "careless and reckless" after the fact.
