CAG Relieved
In my squadron we have so many O-5s, and so few O-1s and O-2s that aren't students, that instead of an "LPA" we have an "LCPA".
Not all O-5s need protection, so to speak...there seems to be more than a few happy to throw anyone under the bus.
- double entendre? Get your mind out of the gutter sir!
As far as officers go, there's no real tension until you are eligible for O-4. Then it gets real. Making O-4 is pretty routine but at this point things start to happen that will define the balance of your career. You've ridden a rocket to O-4, only to realize there is a chance you will retire as an O-4. Up until consideration for O-4, you've been too busy to give the future much thought. As you become eligible for O-4, the question of the next ten years is never out of your mind.
speak for yourself....:D
i'd say 80% of the O-5s I have interacted with are still bros...
Not to mention that it seems to me that all USAF O-5's are approximately 28 yrs old.......
FWIW, the USAF traditionally has had Field Graders pin on 2 years later than the other services -- between 12 and 13 years TOS for O-4. Around 2003 the USAF decided to slide promotion boards to two years earlier than normal (so as to have guys on joint assignments have rank equal to their coworkers from other services), and I ended up pinning on O-4 at 11 years TIS. I pinned on O-5 at just under 16 years TIS -- and I was 38 years old.
AF officers are just taken better care of, with the spa treatment and all... They just age better than the rest of y'all.
I'm curious. Are you saying AF guys/gals are making O-5 with less than "required" time-in-grade (what is it, about 9 1/2 years TIS?). 28 seems really young for an O-5 but, then again, times change.
Just joking around, but I will honestly say that most all of them have looked way younger than our O-5's. Maybe I have just had old looking CO/XO's. I definitely wasn't serious about them actually being 28 :)
What Hacker explained is pretty much in line with average TIS for the Navy side too in all seriousness.
Got it. Thanks. They probable look younger because you are getting older:). What Hacker explained is pretty much the same as when I was in.
