z987k
With the -11, you can exceed torque(mostly just with the AWI on), but it won't let you exceed temps with the SRL working. Love this! Engine failure at V1, power levers full forward. It'll bypass for you. Though some "hard bypass" and you actually get a little less than max power, but it's easy to fix that. If I don't touch a pratt again, I'll be a happy man!Now with the SRL deferred, this is the worst engine ever! Gotta figure out your max allowable temp for t/o, max power, climb(at 5,10,15 and 20 depending on how high you go), cruise, and go around power at your destination. Ugh! Though, not as big of a deal when all of your airports are at sea level and the temperature is 30*C.
The -10's that had the SRL had both torque and temp limit. You could literally just smash em forward in an engine failure, or really at any time if you wanted to.
I also liked how you could cheat a hot start into an ok start with the temp limiter test switch. You could manually trim a little bit of fuel with it.
