So, finally go into the full motion sim last night. Got to see a lot of stuff that either didn't work in the FTDs or were just represented by cardboard cut outs, the O2 mask being one of them. It's a little different than the one in the CRJ, but still pretty simple. The test is a bit different, but easier once you get the hang of it. It's pretty intimidating on paper (the wording of the O2 test takes up almost half a page in the FCOM), but once you actually do it, it's an "Oh yeah!" moment.
Last night was essentially an intro to "this is how the airplane flies." Normal takeoff, steep turns, turning different dampening systems off to see the difference if they fail, ILS approach to a landing, LOC approach to a landing, TCAS RA, wake turbulence on take off, wake turbulence on approach leading to a go around, visual approaches (which the sim does QUITE well, flew a whole traffic pattern) and I think that was pretty much it. With the steep turns, the HUD makes it almost like cheating. There's no scan involved if you use the flight path indicator since every bit of info you need is right there. Keep the horizon line (which has your heading on it) going right through the center of the FPI, and you won't lose more than 10 feet of altitude. There's a trend vector on the FPI that shows your speed and one that shows your acceleration, so you can adjust the power using that. First turn, I lost 100 feet. Second turn I lost 40. Last two, I lost 5. Speed was constant on all four. At this point, I've decided I REALLY like the HUD.
Still getting used to the ram horn yoke. My arm was sore this morning mainly because a) I'm using the OTHER arm since I've been on the other seat for the past several years b) the angle of the yoke works a different set of muscles (it feels like it at least) than the CRJ yoke c) I haven't touched an airplane in a month.
Tonight, we do a couple of the same things, but then we start doing V1 cuts, single engine approaches and single engine go arounds. AQP is nice because there's no transitioning. There is a LOT crammed into each lesson, though. What winds up happening is a lot of snap shots, repositioning and canned "this is how we can re-set up the FMS in less than a minute. Okay? Go."
