Probably not so bad once they started charging for full access however.
Yeah, was a great way to get rid of the riff raff and their commentary.
Hmmm. You know....that could work for here.......
Ever seen the Craigslist rants section? Wwwwwwhoa
Why bother getting upset at reader comments? Half the people commenting don't know the difference between fair and fare or plain and plane. I guarantee none of them know a thing about union relations and law.
All of which is moot. Sure, they don't know the difference. But a negative public perception isn't good for either side. And between the management as well as the union and what both are doing, the biggest entity who loses in all of this, is the name of American Airlines; a proud name with a long heritage. And that's pretty sad.
My point was simply about avoiding comments sections. As far as my opinion on the proud name of American Airlines: With unprecedented scope relief, unlimited outsourcing to other carriers, and multiple domicile closures it's the very brand name of American Airlines that AMR is attempting to liquidate to 'some day' turn a profit.
Some of those comments really irritate me!
According to American,...maintenance write-ups "have covered items such as torn seat pockets, frayed seat belts and malfunctioning coffee machines and passenger reading lights."
American Spokesman Bruce Hicks told The Wall Street Journal that management has "seen unprecedented pilot maintenance write-ups, many at the time of scheduled departure, which is having an impact on our operations" in the past two weeks.
American also said it is cutting flights by one to two percent for the rest of September and October.
The cuts are partly due to an increase in pilot sick days and greater maintenance reports by flight crews led to flight cancellations and delays, Hicks said.
Airlines typically try to keep flying through bankruptcy. But simmering labor tensions at American Airlines have boiled over from the negotiating room to the airports in recent weeks, disrupting operations and leaving a trail of delayed and canceled flights that the airline says is the fault of its pilots.
ing matters worse, last-minute inspections ordered by pilots have more than quadrupled the number of cancellations related to maintenance issues this month. As a result, nearly half of American’s flights are now arriving late at their destinations.
A spike in maintenance work requested by pilots has forced more flight cancellations and delays. Those requests, called pilot write-ups, are sometimes posted after the main cabin door has been closed or the airplane has reached the taxiway, the company said.
Since the beginning of the month, the cancellation rate has averaged 2 percent, more than twice the usual rate. On Sept. 17, the airline said, it canceled 6 percent of its flights because of pilot write-ups. Maintenance requests by pilots are 34 percent higher this month than the same month last year. Another procedure called a precautionary check, which is also ordered by pilots but requires no repair, is up by 97 percent, the airline said.
“Every airline has maintenance issues, every day,” said Mr. Hicks, the spokesman for American.
“We have a system that provides for safe operations and we expect our pilots to write up legitimate maintenance concerns. But the impact on operations has been terrible. Customers see it that way, and rightly so.”
In some cases, the complaints involve serious issues. In others, they are more mundane: pilots have been reporting burned-out passenger lights, frayed seat-back pockets or broken coffee makers, the airline said. As a result, the number of flights canceled because of maintenance issues has shot up to an average of 31 a day this month. That is more than four times the regular maintenance-related cancellation rate of seven, the airline said.
As I said.......speaking of war: I may disagree heavily with US foreign policy on our wars and how our own government is screwing our troops; but that doesn't mean when I get deployed overseas that I go bomb civilians with my jet just so I can make a point.
Writing up a legitimate maintenance item at an inconvenient time that is going to result in someone's flight getting cancelled is hardly the same as intentionally mis-using weaponry to end the lives of people unrelated to the situation.
Writing up a legitimate minor maintenance item that wouldn't have been written up before, but is now written up in order to cause inconvenience and/or a flight cancellation, IS a similar concept. And it does and has happened.
You are looking at this backwards. Prior to the pilots just doing their jobs, they would intentionally violate FARs and NOT write stuff up in order to NOT inconvenience passengers and to AVOID flight cancellations.
Was it a good thing and did it keep the airline (mostly) running on time?
Yep.
Was it willfully negligent and illegal?
Yep.
"...... I can only attribute that to the fact that every guy in the project, every guy at the bench building something, every assembler, every inspector, every guy that’s setting up the tests, cranking the torque wrench, is saying, ‘If anything goes wrong here, it’s not going to be my fault, because my part is going to be better than I have to make it.’ And when you have hundreds of thousands of people all doing their job a little better than they have to, you get an improvement in performance.”
