Severe clear ice. Thank you Kansas city
WOW, quite a perilous story. With personally ZERO ice experience, this story is quite an eye opener.
Glad you made it down safely and sounds like you did a tremendous job as did ATC.
Ice, (more then all other factors combined) scares the daylights out of me. The scariest time ever was when ice was not in the forecast and I was expecting a clear night, only lasted a few minutes, but it sure brought us down in a hurry.
Good job to the OP
Cheated death again! Way to go, you're breathing because you're good. Now don't go and prove yourself again anytime soon, ok?
While I don’t doubt that you encountered ice on that day I really don’t believe it was a bad as you are claiming. After several years of flying the van all over the country with a lot of it based in the U.P. of Michigan and I have never heard of somebody getting much ice that would hamper the 208 in that amount of time. Pilots with 10k plus in the van have never had problems with it responding like it did. I have heard of 4 and saw 4 inches of ice just not in that amount of time.
When the Caravan is covered in ice it doesn’t usually respond in the way you described; such as stalling 10 feet of the runway. That’s really not the airplane fault.
Severe ice like that is usually only a couple hundred feet thick and I believe that you should have been able to climb out of it without much problem especially in with only 1400lbs of fuel and 31lbs of freight.
As far as breaking out at 500agl and stalling 10 feet above the runway
KGAG 200101Z AUTO 01015G26KT 8SM BKN015 OVC019 00/M02 A3004 RMK AO2
KGAG 200148Z AUTO 01025G32KT 10SM -FZRA BKN012 OVC030 M01/M02 A3007 RMK AO2 PK WND 36034/0133 UPB28E30FZRAB30 P0000
KGAG 200053Z AUTO 01020G28KT 7SM BKN013 OVC019 00/M02 A3003 RMK AO2 PK WND 01028/0046 SLP176 T00001017
KGAG 200030Z AUTO 36020G26KT 7SM BKN014 OVC020 01/M02 A3004 RMK AO2 PK WND 36026/0030
KGAG 192353Z AUTO 01018G31KT 10SM OVC016 01/M02 A3003 RMK AO2 PK WND 01031/2349 UPB39E42RAB42E51 SLP174 P0000 60000 T00061017 10100 20006 53037
KGAG 192336Z AUTO 01018G30KT 10SM OVC016 02/M02 A3002 RMK AO2 PK WND 01030/2331
KGAG 192253Z AUTO 01020G32KT 10SM OVC012 03/M01 A2998 RMK AO2 PK WND
01032/2249 SLP157 T00281006
KHHF 200045Z AUTO 02018G28KT 10SM SCT011 BKN016 OVC031 01/00 A3002 RMK AO2 T00101005
KHHF 200025Z AUTO 01016G24KT 7SM SCT010 BKN016 OVC024 02/00 A3002 RMK AO2 T00160001
KHHF 200005Z AUTO 01015G22KT 10SM SCT010 BKN018 OVC030 02/01 A3001 RMK AO2 LTG DSNT E T00220007
KHHF 192345Z AUTO 01015G25KT 5SM -RA SCT010 SCT014 OVC022 02/01 A3001 RMK AO2 T00210009 10084 20021
KHHF 192325Z AUTO 01019G23KT 10SM SCT014 OVC022 03/01 A3001 RMK AO2 T00280010
If the pictures are as you described I will admit I’m wrong and paypal you the money to buy your favorite six pack.
So, uhhhhhh, you weren't there, and you don't know. You can be an ass, or you can take the guy at face value. Your choice. I'll believe him. Metars don't mean a damn thing and you know it. I've been on the approach to an airport with 10SM CLR, and not broken out at all and gone missed. As for "this kind of ice is usually only a few hundred feet thick," again, you weren't there and you don't know. Stop second guessing the guy and give him a pat on the back, he's alive. Even if it was the most ice he'd ever seen, and even if it wasn't 4", it still scared him enough to write about it. Don't be a tool.
Any questions?
I know I wasn’t there and that sometime metars really aren’t all that accurate.
I’m not trying to be an ass or a tool but I think this probably is an exaggeration of what really happened.
Like I said prove me wrong and I will apologize and admit I was wrong.
Good job on getting the plane on the ground safely
wow... really?
wow... really?
Yes really. What else do you want me to say?
I think if you are going to tell a story like this it should accurate and if say you have pics to support it then it should not be a problem to post them.
Once again I am not trying to be a jerk.
So asking someone to prove somthing that they say they can is being a jerk?
On the internet? Yes. If I were him, I wouldn't be posting pictures anywhere of anything. Whether or not some random internet under-bridge-dweller believes what I say on here is of little interest to me, likewise whether they believe someone else. Now put that thing back in your pants.
Yep what he said.
So asking someone to prove something that they say they can is being a jerk?
I'm a pilot at the same company and I can confirm everything in his story. He is fortunate to be alive, and should not have to justify his actions to anyone.
BTW your statements about icing may be accurate in the north, but down here it can be different. What he likely encountered was freezing rain on a airframe that was already below freezing, which can put a LOT of ice on in minutes. None of this was forecast by anyone, nor had any other airplane in the area reported anything.
This is simply another example that despite taking every precaution and doing everything correctly, this is still a dangerous business.
