drunkenbeagle
Gang Member
My boss likes to tell a story of a pilot who was shooting practice VFR approaches into our local class D, while on with KC approach. Apparently, he got all the way to a 1 or 2 mile final before they switched him over, and tower was irate. Tower had a big mess on his hands because this guy came in without any warning.
Well, that's the tower's problem, not yours. Approach control is responsible for clearing you for approaches. Period. You shouldn't be talking to the tower until you get a hand off to do so. They can/should/must clear you into any Charlie or Delta they are working. The approach controller needs to coordinate that with the tower, not you. Especially for instrument traffic in a Delta - the tower controller provides only runway separation there - Approach separates everything else (instrument anyways).
Approach is the appropriate ATC facility to provide clearance through a Bravo, Charlie, and most Delta airspaces. If they want you to talk to tower, they'll hand you off. But as far as legalities go, an approach controller is the appropriate controlling authority. A defined in the FARs. So long as you are talking to them, you are OK in any Charlie or Delta airspace in their sector. Of course, it can be hard to tell what airports they cover if you aren't looking at the IAPs. Short answer is don't worry about it.
Now, you can't be talking to Miami Approach and the bust through the KPVD Charlie for instance, but that isn't going to happen in real life, is it?
A Center controller is not generally the "controlling authority" for Bravo/Charlie/Delta" airspaces. In the real world, Center will tell you "radar service terminated, try XZY approach" -- or give you a handoff if they can. Talking to Center does not clear you into the Bravo/Charlie/Deltas, simply because it isn't their airspace. This is what seems to trip people up.
In those rare cases where a Center controller is giving you VFR flight following to a towered airport where there is no approach controller (there are a few), just tell them you have the field in sight 5+ miles out. If not, well, Center probably has an LOA to clear you in there anyway. So just ask
