wheelsup
Wheels -
Demonstrating a circling approach in a Seminole wasn't that bad... I recommend you do it that way.
Sounds like the voice of experience
Wheels -
Does that take the restriction off his type as well as the ATP? I would guess that would leave the restriction on the type as it was not demonstrated in a type ride. I could be wrong on that. Some of these companies don't want any restrictions on the type.
MW,
I don't know why all the airlines have gone to this CIRC APPR VMC ONLY junk. Why would they not want us to be trained and typed in that. I mean, our OPS SPECS says we can't do it, that should be enough.
For example, you and I are trained to CAT II mins, yet we aren't allowed to shoot CAT II approaches....per OPS SPECS so why do we do it? I know there are a couple of other things as well I can't remember so why is this any different. Just find the highest circling approach mins at any airport we go to and have us do it and that will be good enough.
Just my two cents.
Plus I'm not sure how you'd really demonstrate a circle in a sim, even a Cat-D.
Easy.Plus I'm not sure how you'd really demonstrate a circle in a sim, even a Cat-D.
Sounds like the voice of experience. Did you just rent a seminole for an hour or two and go up with an MEI to get proficient again, then call a DPE and schedule a time? I'm kinda outta my element here, every training event I've ever done was "structured" in some way.
...you can. At least I can. Maybe not the landing runway at times, but I can see the airport for a reference point.I guess its just me but there's something odd about not being able to see the runway when doing a circle in a sim to prove you can in fact do a circle.
gotchaI actually did my ATP outside of work, and that including a circling maneuver. If I were you, I would see if a school would rent you 3-5 hours of Seminole time and then speak to a DPE about testing.
Do you have an SIC type? I know every place is different but at my current 121 the SIC type has the restriction but the PIC type removes it.
Flight Safety in Houston will remove the restriction for EMB-145 type rated pilots. IIRC, it costs $2,000, but if you find a partner you can split the costs 50-50. If an overseas employer required it as a condition of employment, I would tell them to pay for it or "no thanks".
