tilley_205
Not sure if this is the most appropriate forum to place this question, but what is the proper way to request and execute an overhead break?
Not that I have any desire to nor have I ever heard anyone request this but could a civilian pilot be approved for a break or is it reserved only for military aircraft?
When I was younger and flying with my dad, he used to do it in his Bonanza at uncontrolled fields that weren't real busy. That said, I would probably not do it in a civilian aircraft. Really doesn't accomplish much and likely confuses the crap out of other traffic who don't know where to look. Normally jets fly a higher traffic pattern at civilian fields which kind of deconflicts the airspace for safety, which you wouldn't have at a normal pattern altitude.
The way we execute is a 5 mile initial (which you report to tower) at 250 indicated, then you push the nose over, power up, switch of the transponder, and accel to break speed (350 IAS or so). Tower will normally have you report numbers for the break (approach end numbers), and once you make that call they will clear you to break in pattern direction or specify when to do it (normally a "your interval is xx oclock"). You need to have an idea of how much you will be overtaking downwind traffic by on rollout. We normally do an idle break with speedbrakes, pulling about a G for ever 100 kts and playing it out to a 1 mile abeam. Ideally you should be in landing configuration and on speed (or your approach speed) once you get to the abeam/180 position. Call for your landing clearance, and execute a circling approach turn to roll out on final.....no base or square turns. Pick up the VASI/PAPI (at civilian fields) and fly it to touchdown. Break later for higher airspeed breaks as you will need more time to bleed down airspeed. Having never done it in a civilian aircraft I can't really comment on technique there, but this is essentially what the tower is expecting you to do.
At SCK, I will normally call the direction and break point, because of traffic. Normally it goes like this,
Roper 11 "Stockton Tower, Roper 11, inbound, request initial/overhead"
Tower : "Roper 11, Stockton Tower, (right/left) turns, pattern altitude one thousand, five hundred, report (3-5) mile initial"
Roper 11: "Roper 11, initial"
Tower : "Roper 11, Break (approach end, midfield, departure end, your discretion report break, [or, "I'll call your break"]"
After the break, I clear them for want they want to do, either option or to land.
I've heard this a fair amount at Elmendorf, "Scars 26, fly Tac initial for RWXX, contact tower." Or something to that effect, is "Tac" initial a specific procedure, or something else?
Mil fields also have two patterns: an inside downwind and an outside downwind. Pattern for the overhead is normally 1500 or 2000 AGL, vice the 1000 standard for the square pattern; but can be up to 3000 AGL. The inside downwind, or closed pattern, is the pattern that's entered after the break from initial and when preparing to make the 180 to final to land. The outside downwind is for pattern spacing and to set up for a straight-in following a a touch and go or low approach, or to come back around and re-enter intital without affecting the inside downwind
Must be a crazy AF thing....I think your inside downwind is analogous to our standard traffic pattern (at least so my Vance friends have told me). We do 900 AGL "Carrier break" with 600' AGL on downwind. Also USN controllers don't use the closed traffic phraseology that every other controller in the world uses, for whatever reason. Interesting to see the differences between services. I also have never heard of the Tac initial you described, though I have seen a couple fan breaks (not permitted in orange and white trainer land unfortunately).
Fan breaks seem standard for the USN. But then again, you guys fly patterns gear down(actually, probably more efficient).
Yeah, the standard carrier break I've heard is 800/600 AGL, but seems the same as you describe. Another USN funny I saw is this: At DMA, the runway is 13,600'. A-6E Intruder enters the pattern and breaks, approaching the 180...begins the final turn, and proceeds to plant it on brick-one of the runway, plopping it down carrier-style. Probably habit or to keep with training, but I was half expecting some semblance of a flare and smooth touchdown, seeing as to the runway length. Just found that funny.
This is a typical exchange most everywhere I've done it (sts).
Fortunately I've never had a tower controller say "what?" in reply to my request for initial!
There is a Mustang pilot in JAX that does it nearly every landing. It's dang cool to see.Not that I have any desire to nor have I ever heard anyone request this but could a civilian pilot be approved for a break or is it reserved only for military aircraft?
