wait so civilians fly overheads too? I thought it was just the military
Break later for higher airspeed breaks as you will need more time to bleed down airspeed.
We do 900' AGL "Carrier break" with 600' AGL on downwind. ...though I have seen a couple fan breaks (not permitted in orange and white trainer land unfortunately).
800' AGL carrier break. I've done a handful of fan breaks in the mighty Goshawk, was in a C-9 one time that came in for the break, that was a little scary.
holy crap i have no idea what is going on. can someone post a diagram?
all i know is i have seen (insert cool jet name here) do a cool approach with a lot of high bank turns and swooping right to the numbers.
diagram would help a lot here....
Good catch, yes 800 AGL (apparently I suck at math 1100-300 =/= 900). As for breaking before the numbers, I'll let you fleet guys mess around with thatEven at the numbers I'm either hardcore LIG or on speed by the middle.....at least at a non-girly break speed
FAR/AIM; said:![]()
5-4-26. Overhead Approach Maneuver a. Pilots operating in accordance with an IFR flight plan in Visual Meteorological Conditions (VMC) may request ATC authorization for an overhead maneuver. An overhead maneuver is not an instrument approach procedure. Overhead maneuver patterns are developed at airports where aircraft have an operational need to conduct the maneuver. An aircraft conducting an overhead maneuver is considered to be VFR and the IFR flight plan is cancelled when the aircraft reaches the initial point on the initial approach portion of the maneuver. (See FIG 5-4-27.) The existence of a standard overhead maneuver pattern does not eliminate the possible requirement for an aircraft to conform to conventional rectangular patterns if an overhead maneuver cannot be approved. Aircraft operating to an airport without a functioning control tower must initiate cancellation of an IFR flight plan prior to executing the overhead maneuver. Cancellation of the IFR flight plan must be accomplished after crossing the landing threshold on the initial portion of the maneuver or after landing. Controllers may authorize an overhead maneuver and issue the following to arriving aircraft:
1. Pattern altitude and direction of traffic. This information may be omitted if either is standard.
PHRASEOLOGY-
PATTERN ALTITUDE (altitude). RIGHT TURNS.
2. Request for a report on initial approach.
PHRASEOLOGY-
REPORT INITIAL.
3. "Break" information and a request for the pilot to report. The "Break Point" will be specified if nonstandard. Pilots may be requested to report "break" if required for traffic or other reasons.
PHRASEOLOGY-
BREAK AT (specified point).
REPORT BREAK.
FIG 5-4-27
Overhead Maneuver
The question for me becomes, if you are breaking out on an approach lined up with the runway, why aren't you continuing the approach to the deck? Is it so you can fly the approach as fast as possible? or something else.
The break is generally a VFR entry into the pattern. If the field is IMC, then our standard procedure (as the break is unavailable) is a clean GCA to downwind. In other words you break out at some point on the approach, switch to tower and just turn downwind and dirty up.
If we are doing an approach for training, then on missed we request to depart and re-enter for the break. You can of course continue a GCA to full stop, but that would be seperate from entering via break. The most common is when weather ceilings are above initial altitude, in which case you get ATC vectors down under the wx, get the field in sight, switch tower and proceed VFR for the initial.
Edit for reading comprehension: I realized what you are asking. Doing the break expedites getting to the field, getting dirty and getting on deck, and helps ATC sequence aircraft into the field. Rather than flying 120-150 kts for a 10 mile straight in, you do 300-350 (or more for grey jets) all the way in from 5 miles, break, and get on deck
Yes, pprag. Like I said before it's the fastest way to get tactical jets into the pattern and on the ground.
Once you come up initial, you're considered in the pattern and the only radio call that needs to be made is to report initial at the requested point, and report base with intentions, where you come off the perch in 180 degreen turn to land.
Is "perch" synonomous with "abeam" MikeD? We use it in the ACM sense, but I hadn't heard it used otherwise
I dont think I have ever broke to the left we usually always break to the right for right traffic.
You ever fly out to SCK?Anytime I fly a formation element at KLVK I do an overhead break. If I am in something cool as a single ship I request a low approach. I usually get a 4 mile initial at 2,000 feet. I dont think I have ever broke to the left we usually always break to the right for right traffic. Every airport I have been to has been really accommodating for overheads.
Back in the day, tons.
