SpiceWeasel
Tre Kronor
Yes, I'm working on instrument now. I never fly Cessna before, that is the reason the first day he show me how to pre-flight a Cessna. Btw, I got the private license in another school.
Well, it's a piston single.... you have SEL rating, I presume... you aught to be able to preflight the aircraft without prompting or aid from your instructor. Take a look at your PIM, or "Pilot Information Manual", the generic version of the POH, and it should give you a walkaround inspection. New Cessna, sump all 13 drains, older Cessna, you only sump around 3.... make sure prop is on in the right direction, the alternator belt is there, enough oil is in (6 to 8 quarts I bet), the tires and wheels and brakes look acceptable, and that your flight controls are connected. Also, check lights, and outside P-S instruments....
I think that about covers the pre-flight of a 172.... easy-peezy....
As far as switching instructors.... I see you're in Chicago but if you make your way down to San Diego there's a guy on here who is desperate to fly for free.... you might want to try that out.
