Flight following / Class B clearance
USRaven
New pilot... Easy question~ (positioned northeast of Sarasota class C, and south of Tampa class B)
I am on flight following in Class E approaching Class B. I am at 6,500'. I have been given vectors to avoid a fast mover departing from sarasota class C. The vectors I have been given will put me into CLASS B AIRSPACE. Do I request transition into the class B, or is it already assumed I am cleared because I have 2 way communication established?
I know that you must be CLEARED to enter class B, but only need to establish comm with class C and D... the reason I ask is that the controller was so nonchalant about it when giving me the vectors.
Thanks!
Thanks!
ATC should know where they're vectoring you, but should also inform you of same. If you're uncomfortable with it (or with anything ATC does), query them.
The REALLY interesting (and sad) thing is how many pilots wouldn't even know they were being vectored towards another airspace.....ie- once they get flight following, they sit fat/dumb/happy thinking that ATC will fully take care of them, akin to being IFR. That's even if they have SA on where their aircraft is in relation to other airspace in the first place!
The NTSB has ruled that if you have been assigned a heading and altitude that takes you into class B, then that constitutes an implied clearance. However, if they assign a heading only, no such clearance is implied and you can be violated for a Class B violation.
In the interest of presenting pertinent info, see the attached Letter of Interpretation on this subject.
  • Chief Counsel LOI-Granby.pdf
Same thing I was saying. The PIC better know where his aircraft is at all times, and understand that VFR flight following isn't akin to IFR handling. ATC should coordinate for you if they're going to vector you towards airspace that would require a clearance, but if they don't, then the PIC must have the overall SA to inquire about it, knowing where his aircraft is at all times as well as where it's going.
Thanks!
In my experience, I normally got an honest "thank you" from the controllers when ever I asked them "am I cleared into bravo?" after a vector or altitude that would take me into Bravo. Typically they would then follow that up with, "cleared into bravo...".
Once though he did come back with a new vector...
Be polite and query them, every time if you are still waiting for that clearance.
I would query them regardless. I don't want to enter Bravo unless I hear the words cleared, and I would rather the controller and I be on the same page (ie him not realizing he vectored me into bravo)
That is exactly what you should do. It is best to get that actual clearance on tape instead of just hoping the assumption is there. They can't bust you if they say "cleared through the bravo". I even ask for clearance though the bravo even though I may not quite enter the airspace. I have had a few flights where I passed about a mile or two from the bravo. I ask just in case as students will get off course.
And not only to have it on the tapes to make sure you don't get in trouble, but I want to make sure the controller is also aware of the fact he vectored me into Bravo.
I can only imagine him seeing me in the bravo, not cleared, and is trying to figure out what happened while 2 other airplanes on the other side of his scope are in conflict.
Got a reference to that?
It's certainly somewhat related but why is an opinion regarding airspace with only a requirement to establish 2-way communications particularly pertinent to airspace which requires a specific clearance?
It's certainly conceivable to blunder into Class C while still yakking away on a Class D Tower that you are talking to, but there is no way I can think of that one would hear "cleared into the Class B at 3000'" from a Class D Tower (or Class C controller for that matter) unless that specific clearance was being relayed.
Mark,
I felt it was pertinent to the discussion because the OP mentioned being vectored to avoid an aircraft departing Class C. He stated he was in Class E, but apparently must have been fairly close to C to have received a vector to avoid departing aircraft.
I don't think the letter implied that the aircraft would have been talking to a Class D tower prior to entering Class C, but perhaps I misunderstood your statement. They were referring to being in contact to Center.
The letter only addresses Class C ops, but I think it is interesting to see what the CC says about being in contact with the ATC facility versus any ATC facility. It's the wording they use that I found interesting. Even though it was Class C, the same wording is found in 91.131.
(1) The operator must receive an ATC clearance from the ATC facility having jurisdiction for that area before operating an aircraft in that area.
I'm not saying the letter answers all the questions, but in a discussion of this type, I think it is of value to know, generally, how the CC views the regulations on this.
gary
TPA Approach is kind of lax about this, get used to it.
You NEED to have a clearance to enter the Bravo airspace. Period. A vector that takes you into the Bravo is NOT sufficient if you are VFR. (It is if you are IFR).
They CAN vector you into Sarasota's Charlie, or MacDill, PIE, and SPG's Delta's without any explicit clearance. Just talking to them is enough to transit those airspaces.
If you are getting near the Bravo, just say "N12345, verify clearance into the Bravo." Do a 360 if you can't get them on the radio (TPA approach isn't that busy, you'll almost always be able to get a word in)
Around Tampa, just get in the habit of saying "Request clearance through the Bravo" when you call them initially. Something like "Skyhawk 1234, 10 North East of SRQ, 6500, request flight following to KZPH and clearance into the Bravo." Even if you don't think you need the clearance, ask for it anyway, since there is a good chance they might vector you in for traffic.
7 N.T.S.B. 649, NTSB ORDER NO. EA-3238
ADMINISTRATOR v.JAMES RYAN, RESPONDENT
Adopted: December 11, 1990
*649 OPINION AND ORDER
The Administrator has appealed from the initial decision that Administrative Law Judge Joyce Capps issued from the bench at the conclusion of an evidentiary hearing held on March 13, 1989. The law judge reversed an order of the Administrator that charged respondent with entry into the New York Terminal Control Area (TCA) without appropriate authorization from air traffic control (ATC) before doing so. The law judge found instead that respondent's entry into the TCA had been "constructively and tacitly" approved by a controller who gave him "a heading, an altitude instruction, that would take that pilot through a TCA." Although the law judge pointed out that a specific request to enter and a specific affirmative response would have been preferred, she determined on the basis of the evidence that respondent was legally in the TCA.
In the circumstances of this case, the law judge found that this handling by the controllers resulted in constructive or tacit permission to enter the TCA.
Respondent argued that, after leaving the Teterboro tower, he contacted an intermediate controller who instructed him to follow the course and altitude at which the TRACON departure controller found him. He believed that following the instructions from this intermediate controller amounted to an affirmative defense for his unauthorized entry into the TCA. The law judge found that "by giving a pilot a heading, an altitude instruction that would take that pilot through a TCA, that is tantamount to a clearance."
The problem with this ruling, IMO, is it allows the pilot to get into a mode of "just along for the ride" in regards to letting ATC drive him around; rather than maintaining the SA as to where his aircraft is now, and is going, at all times. THAT is a PICs responsibility, IMO. Whether or not an "implied" clearance was given by ATC issuing a heading and altitude; to me, it's a cop-out for a pilot to try and shoulder ATC with the blame for their own failure to exercise PIC responsibility.
Rather tough for a /U aircraft.
Regardless, the FAA has never specified what form a Class B clearance should take.
Tougher, yes, but not impossible. Especially VFR. True, the clearance form has never been specified, just that one have a clearance. In that realm, a PIC should have the forethought to know where his plane is headed, and for me at least, I'd query if I'm in fact cleared into a TCA based on where I know a certain heading/altitude is taking me. The reasoning for it being that I'd rather query, than make an airspace bust later when it could've been avoided on my end. And that's assuming it's a simple bust and not one that involves a near-miss or worse. I just believe that even with ATC helping us, we as PICs still have a responsibility to "trust but verify". Anything less is lazy at best, or the PIC being behind the aircraft at worst.
"Cleared into the Bravo" works for me. Or "XYZ transition through the Bravo approved." A heading isn't enough. The controller may have only wanted you on that heading for a minute to keep you clear of other traffic, or other airspace. While the FAA may not throw the book at you, it is certainly more desirable to always get a positive clearance into a Bravo.
I don't think being /U makes it impossible to know where you are. Look at the Terminal Area charts. It is the PICs job to know the airspace and especially the geography and landmarks if you are VFR.
