poser765
PIC and no one the wiser...How would this flight be logged if I wasn't sole manipulator? Just curious
I kid, I kid.
but really I would.
pff no i wouldn't
but maybe.
nah...
. Yeah. Your CFI was wrong.Anythoughts?
What about logging complex time? I did not have my complex endorsement while being the sole manipulator of a C172RG during some of my instrument training (the regular 172 was on mechanical so we took the RG). I logged it as PIC/complex time and during my commercial training my instructor told me its not PIC until you have your endorsement. Anythoughts?
This should be easy enough, 61.51 (E)(1)(i): Is the sole manipulator of the controls of an aircraft for which the pilot is rated or has privileges
Part 1, page 9 definitions:
Rating means a statement that, as a part of a certificate, sets forth special conditions, priveleges, or limitations.
Then refer them to chapter 1 of the Jeppesen Private Pilot book and let them read what in fact are ratings, they are all listed in chapter 1. Next jump on to 61.31 (e), (f), (g), and (i) noting for each of these the word endorsement is located in the regulation (it is located in the last paragraph of each reg). You can log PIC because you are rated to fly airplane, single engine land. You just don't have your endorsement required to operate as PIC per 61.57 meaning you cannot be the sole manipulator or the only rated pilot on board acting PIC. This doesn't prohibet you from logging PIC as per the above FAR since you are rated for that single engine land aircraft. In short, as long as you are rated for that aircraft you can fly it.
For comparisson sake if it is argued that gliders are under this same section. Reference 61.31 (j)(1)(iii)(2): "The holder of a glider rating..."
This one is a pretty clean cut one if you ask me, it just requires a little extra research. Good luck maybe your buddies will believe the federal government (careful don't be too trusting!).
...and props (no pun intended) on the Pilatus time. I don't know why, but I love that plane (haven't flown one yet)
It's an incredible plane. I think it's impossible to make a botched landing in it with the 16 inches of travel on the trailing linkage gear. Even my first one was a greaser (it should've smacked down lol). Lots of power, obviously compared to my measely c-172, and very terriffic performance. I was wondering why the PIC kept putting it on autopilot so soon and when it was my turn to fly, I had to hand-fly it... I know why he uses autopilot lol. That thing is very heavy and its difficult to control all that power (again, I'm coming from my 150hp c-172) without overcorrecting on pitch and/or power use. I loved it and really would like to go up again in it.
and I was wondering how I'm supposed to log this. I wasn't PIC (I'm not trying to log it as such, either) nor was I a required crewmember (which would disqualify me from logging SIC) and the other pilot, who was the PIC for the entirety of the flight, was not an instructor (so it wasn't dual received). I was sole manipulator of the controls, if that helps. Another instructor told me to just log it in my logbook and basically leave the three types of piloting time empty, those three mentioned above, and just fill in the total time box. Can I do this? Is there a better way of doing it? If I can't/shouldn't log this as any flight time, I'll more than likely simply put the date in the logbook and leave everything empty (hours and all) and just fill in what happened in the remarks section so that I can reminisce.
Thanks
61.31 - has to do with the service ceiling, not the actual altitude flown at.
(g) Additional training required for operating pressurized aircraft capable of operating at high altitudes. (1) Except as provided in paragraph (g)(3) of this section, no person may act as pilot in command of a pressurized aircraft (an aircraft that has a service ceiling or maximum operating altitude, whichever is lower, above 25,000 feet MSL), unless that person has received and logged ground training from an authorized instructor and obtained an endorsement in the person's logbook or training record from an authorized instructor who certifies the person has satisfactorily accomplished the ground training. The ground training must include at least the following subjects:
As for Jamin, I would have logged it as dual received, no PIC. Again your not technically rated in the aircraft and it was a 1 time deal for training purposes.
If I were reviewing your logbook and I saw pilatus PIC time I'd be sure to ask you a couple questions about the systems
And if he gave you an answer would you know if he was right or not?
Maybe at one time he knew everything there was to know about a Pilatus but say its been 5 years, should he still remember everything. I flew a Caravan for 18 months and I can't remember a thing about it. Does that mean I wouldn't get the job if you asked me about it.
There's no gray area at all. He was sole manipulator of the controls in an aircraft for which he is rated (Airplane Single Engine Land). Case closed.I hate regs. This is the gray area...
