When starting a turbine engine, how do you know its started?
For the Garretts we have the SRL computer that does the magic for us. But we are on speed at 65%. That is when the generators come online. The starters kick off at 60%.
On the TBMs I flew, the procedure was to put the prop lever in full fine pitch/high RPM right away, to give a little extra cooling (or at least that's what I think the stated reason was, it's been a few years).
I probably grammatically bungled that original post, but I meant to say 12% N1 -> Condition Low Idle, Prop Forward. On the TBMs is it prop forward before hitting the starter?
Yes. Mind you, I wasn't privy to all the details of that propeller system, since I only got about 10 hours in the things.
Everyone is correct, and I'm just adding videos and quick summary:
Jets drive the intake compressors by turbine blades. We need the air to go in one direction, front to back. When it is up to speed, the inertia of the air and pressure forces air to go back, even when it's exploding. If you don't get enough air pressure or speed, the explosion in the combustion stage will force air from back to front, creating a compressor stall. Also, the temps in the turbine section are incredibly high and need special materials to work. If the explosion goes forward we will severely damage the engine. As such, we need to "spool" or spin the engine up so we have enough air coming in the front before we introduce a flame to the combustion and turbine section. To do this we either use an electrical starter (like piston aircraft, in sorts), air compressed from an external source (ground unit, or APU - which itself is started by an electrical starter), or by compressed air into an engine starter that spins a gearshaft to spin either the compressors, or the turbine section. Depends on the engine.
GE CF6 start: Packs off, check duct pressure ~30 psi, open the start valve, at 20% N2, introduce fuel. Chugga chugga chugga. Rolls back to a stable idle, red start limit tick on the EGT display goes away. Rinse and repeat. Go fly! Easiest starting engine I've seen; lights off almost instantly. Now, the triple-spool Rolls RB211 is another story, but it's British, so 'nuff said. :P
Are you asking about a turbo-prop at the end of you're question? Those are a different beast, and there are two fundamentally different design philosophies for them: Direct-Drive (Garrett) vs. Free Turbine (Pratt & Whitney PT-6). PT-6s are weird because they're mounted backwards, and are cut in half... :)
I was. I've spent many hours lying awake thinking about how 1000shp gets reduced enough to spin a propeller a couple (twenty) thousand RPMs, into a 250mph frenzy, without destroying itself....
Mmmmmmm.... TBM.... Tell me that thing flies as well as it looks.
Absolutely. No bad habits that I could tell. Don't get it slow and then jam on go-around power, you're going to have a bad time.
I was. I've spent many hours lying awake thinking about how 1000shp gets reduced enough to spin a propeller a couple thousand RPS, into a 250mph frenzy, without destroying itself....
I've got two 1546 shp engines reducing 20900 rpms to 1190 at the tail rotor and 258 at the main rotor. Crazy!
This. How does it work??? Honestly.
Via gear reduction gearing. In the UH-1H, the N2 power turbine output goes through a reduction gear, where the speed is reduced by 50% to that of the output shaft- the one connected to the transmission. The helo's transmission cant take an input speed of around 20,000 rpms that's being generated, so it gets reduced before that point. For the tail rotor, there are further gearboxes that have reduction ratios to them. N2 about 20,000 RPM, to the short shaft of around 6600 RPM, to the main rotor of 324 RPM.
GE CF6 start: Packs off, check duct pressure ~30 psi, open the start valve, at 20% N2, introduce fuel. Chugga chugga chugga. Rolls back to a stable idle, red start limit tick on the EGT display goes away. Rinse and repeat. Go fly! Easiest starting engine I've seen; lights off almost instantly. Now, the triple-spool Rolls RB211 is another story, but it's British, so 'nuff said. :p
On the ERJ, the ITT gauges display whatever the start limit was only when the engine isn't running - so it's regional pilot proof :) After start, the arc extends up to normal T/O-1/TO/ALT T/O-1.
