ASpilot2be
Qbicle seat warmer
For the Garretts we have the SRL computer that does the magic for us. But we are on speed at 65%. That is when the generators come online. The starters kick off at 60%.
On the TBMs I flew, the procedure was to put the prop lever in full fine pitch/high RPM right away, to give a little extra cooling (or at least that's what I think the stated reason was, it's been a few years).
Yes. Mind you, I wasn't privy to all the details of that propeller system, since I only got about 10 hours in the things.I probably grammatically bungled that original post, but I meant to say 12% N1 -> Condition Low Idle, Prop Forward. On the TBMs is it prop forward before hitting the starter?
You are not a jerk and it was not taken that wayDidn't mean to be a jerk, for some reason I thought the OP was high time, or at least flew from regionals and was trolling.
For the Garretts we have the SRL computer.
We need the air to go in one direction, front to back.
Fair enough, but still continous flow... nice try... nice try...Or, in the case of a PT-6...
Are you asking about a turbo-prop at the end of you're question? Those are a different beast, and there are two fundamentally different design philosophies for them: Direct-Drive (Garrett) vs. Free Turbine (Pratt & Whitney PT-6). PT-6s are weird because they're mounted backwards, and are cut in half...![]()
Absolutely. No bad habits that I could tell. Don't get it slow and then jam on go-around power, you're going to have a bad time.Mmmmmmm.... TBM.... Tell me that thing flies as well as it looks.
I was. I've spent many hours lying awake thinking about how 1000shp gets reduced enough to spin a propeller a couple thousand RPS, into a 250mph frenzy, without destroying itself....
On the TBMs I flew
Haven't flown that TBM (yet, if any of them are still flying).Sweet R-2600 radial there, all 14 cylinders purring along, firing just right.
Haven't flown that TBM (yet, if any of them are still flying).![]()
I've got two 1546 shp engines reducing 20900 rpms to 1190 at the tail rotor and 258 at the main rotor. Crazy!
This. How does it work??? Honestly.
On the ERJ, the ITT gauges display whatever the start limit was only when the engine isn't running - so it's regional pilot proofGE CF6 start: Packs off, check duct pressure ~30 psi, open the start valve, at 20% N2, introduce fuel. Chugga chugga chugga. Rolls back to a stable idle, red start limit tick on the EGT display goes away. Rinse and repeat. Go fly! Easiest starting engine I've seen; lights off almost instantly. Now, the triple-spool Rolls RB211 is another story, but it's British, so 'nuff said.![]()
