I'm going to have to agree with pprag and say that is some of the conditions we deal with in AK you want it on the ground ASAP. On the majority of the runways we fly into with a 207 there is no such thing as a VASI and it is entirely up the pilot's judgment. On anything up here under 2,000' (and that's a lot of runways) you're number one priority is to get the mains down quick and get the airplane stopped, with no points awarded for finesse. Anything longer than that and you have a little wiggle room, but not much.
On the one 135 checkride I've done up here in the 207 the checkairman wanted to see me down and stopped in the first half of a 1,400 runway. The trick is be on airspeed, aim for the threshold (or maybe a little before in the terrain allows), minimal flare, and get on the brakes.
Now, not to pick on anyone but I will say that flying down here in the lower 48 tends to make me lazy. I haven't been into a runway shorter than 4,000 in a LONG time. I have to continually force myself to pick a spot and hit it every time because when I eventually get back up north that will be my world again.
Standard procedure for me is as soon as the mains are down, retract the flaps as I want to have as much weight on the wheels as soon as I can. However, I will qualify that statement by saying my day job currently has me in a fixed gear single.
I have in the past anticipated touchdown by a little and just retracted the flaps on short fields in the moment before touchdown but it's not a technique I can really recommend. The Caravan had a tendency to plant really hard when you did that and that really did strange things when you've got larger tires on it. The 207 is a little more forgiving of the technique but I'll let pprag talk about that if he wants to.
Do any of you guys ever retract the flaps a few degrees to put the plane down when you're floating along in ground effect using up runway? I'm not talking about 10 feet above the ground or more, but one or two feet up when you want to put 'er down and get on the brakes.
(just in case
