WS
If this is something that you are really serious about, I would suggest one of the fast track programs like ATP or something similar. I have met a few folks that went through ATP, and they all said it worked well for them, but that it was a VERY intense training period. You REALLY need to do as much reading as possible and be ready to go from day one, and really work at it to succeed. I don't know the specifics, but I THINK they wanted you to complete your written test before you even start each part of the program.
One thing to think about here that will certainly affect the cost is how you go about your training. If you aren't able to take a significant amount of time off work and really hit it hard like you would have to with one of those programs, you are going to cost yourself more in the long run by doing it part time at a local flight school. If you aren't flying AT LEAST 2x a week, you are going to lose some of that knowledge and end up spending more in the long run as you won't retain as much between flights.
If you decide on a local flight school, make sure to choose one with enough airplanes and instructors that you will be able to fly often and have access to an instructor for any ground training that you might need as well. Lots of instructors at the smaller schools are part time, and it can sometimes be difficult to get a consistent schedule with an instructor. While I DO recommend flying with different instructors, if they aren't communicating with each other, and following a common and organized curriculum, that can also slow you down.
I'm sure ATP would have a very standardized set of lessons for each course that each instructor would follow, which would probably help with that, where a small flight school would likely be a lot less organized and put more of that responsibility on the individual instructor. If you do the small school route, Part 141 instruction would be a bit more organized which would help with that, though not all schools are set up to deliver that.
