Nick
Ummmm . . .
What -- do you think that a pilot will face some kind of punishment if they can't get every seat filled due to a weight restriction?
Ummmm . . .
But I have NEVER myself or have seen a captain take off out of CG or above legal weight.
i guess you dont commute.
Incorrect guess.
I've done a trans-con commute and currently do a shorter haul commute.
What does that have to do with it?
If a flight needs an alternate, or there a lot of bags, or whatever the case may be:
the PIC of that flight should not be creating make-believe half weights and putting it on the weight and balance.
Period.
Paragraph.
Anyone who does that does not even value their own pilot certificate!
The FAA can be standing in the jetway upon arrival counting the number of kids and comparing it to the weight and balance. They have done that and I certainly would not be the one to come up with an explanation as to why there are six kids on the paperwork but none on the airplane, and that the difference in the two weights makes the flight overweight.
I think what he was referring to was when airlines use the "wiz-wheel". There can be a LOT of fudging involved in order to make things work. Not to mention, two people can spin the same problem and get different answers.....they may be in the same ballpark, but still different...you generally go with what works. At ASA, if we have a jumpseater, many times the ACARS "won't work"...ie "no comm". So unfortunately *cough cough* we have to figure things with the wiz wheel to see IF they will work. Remarkably, the jumpseater usually gets on.
