LoadMasterC141
Page 12-2 of the AFH states that "Unless otherwise noted, when V-Speeds are given in the AFM/POH, they apply to sea level, standard day conditions at maximum takeoff weight".
However,
FAR 23.149 sates VMC airspeed must be calculated at the most unfavorable weight. Unless there is a situation I don't know of, the lightest weight gives the least horizontal component of lift to aid the rudder.
So the FAA has contradicted itself? Had a student bust an initial MEI because he said that the most unfavorable weight should be used to determine the VMC airspeed, and that is the lightest. The examiner cited 12-2 and failed him.
However,
