Why the slower speed for lower weight? Well, in general, a lighter airplane can maintain level flight at a particular airspeed with a lower angle of attack. So the cruise to critical AoA gap is larger at lighter weights. So we need to slow down more to get our cruise AoA where we need it to be to keep the gap manageable.
That's exactly it. Va is a stall speed for your max load factor. Which means Va goes down for the same reason the stall speed goes down with less weight.
This definition while theoretically true and will give you your Va gives no practical understanding of what is happening and if you say this to your FAA guy you had best be ready to back it up with the AoA gap explaination.
Thank you for going into detail in showing the why for weight for Va is because of the AoA gap not because stall speed goes down.
To that that this is wrong, simply because you prefer to focus on the "gap" is a bit silly, IMO. They're both important concepts.
reach it's load limit at a lower airspeed as well
they vary directly with one another mathematically, but the reason for them changing is not the same.
The reason stall speed decreases with weight is the exact same reason as why Va decreases with weight, as has previously been described. Va = Vs at your limit load factor. Whether you choose to describe it mathematically as opposed to in terms of AoA gap completely depends on your audience. If I were describing it to a Math/Physics/Engineering major I'd do so in mathematical terms, if I was explaining it to the average student (who doesn't appreciate mathematics) I'd be talking about AoA gaps.
The reason is the same, but personally prefer the mathematical terms, but then I have an Engineering degree. As an instructor, it is all about adjusting our style/technique to suit the student, and not the other way round.
tgrayson said:The equation I provided shows you're wrong; the mathematics works because it describes reality. If I were you, I wouldn't fall on my sword on this one.![]()
Not to beat what may be a dead horse and I know many qualified people have explained, but here's a qualitative explanation that helped me to understand...
Remember, the wing always stalls at the same angle of attack, blah, blah. The amount of lift being produced when the wing stalls depends on the airspeed. At high airspeeds, the lift produced is probably at the design limit of the wing--say, for example, 8000lb. (Using a hypothetical 2000lb gross wt airplane designed to 4gs).
Now say the same airplane is flying at gross weight Va and hits the hypothetical gust, but the actual aircraft weight, instead of being 2000lb, is now 1400lb. The wing still makes 8000lb of lift when it stalls, but now the airplane, instead of being subjected to 4gs, is now subjected to 5.7gs. The wing is still fine, but what about the engine mounts, seats, instrument mounts, cargo restraints, floors, etc...They've been subjected to loading beyond their design limits. Hence the varying Va.
Sorry to say, but that doesn't make much sense to me. You say at high airspeeds, the lift produced is at the design limit of the wing -- 8000 lbs for a 2000 lb airplane? That's only the case in a 4g load condition, not straight and level flight.
How does the aircraft's actual weight change from 2000 lbs to 1400 lbs?
Maybe I'm just reading this completely wrong.
Yes, he was talking about the lift produced AT STALL. You are absolutely correct that he's not talking about straight and level flight. He's talking about a stall at max-g... an "accelerated" stall.
So for his hypothetical airplane, which was designed with Va based on 2000lbs. Gross Weight and a 4g load limit, when you pull "g" on the airplane you get to 4g (which is 8000lbs of lift) and then it stalls, because that was how he designed the hypothetical airplane. It's got a 4 g load limit, and at Max gross of 2000lbs, so at Va, it stalls at 4g. For sake of argument, let's give it a hypothetical Va also... say 200 KTAS.
Now imagine the same airplane, but it's lighter... 1400lbs. Maybe you've been flying around for a couple of hours and burned off fuel or whatever. So at that same speed, 200 KTAS, you pull back on the stick and you still get 8000lbs of lift before the stall. But since the airplane is lighter, 1400lbs vs. 2000lbs, the g has gone up. 8000lbs./1400lbs.=5.714 G instead of 4 g. So basically you are capable of producing more "g" than the load limit of the airplane at 200 KTAS and at this gross weight, than you were capable of at 2000lbs. If you slowed down, there would be less g available. At some slower speed, (167 KTAS actually) the airplane would stall at 4 g, the limit load factor, and the lift produced would be 5600lbs. This new airspeed (167 KTAS) is the maneuvering airspeed at this gross weight.
Maneuvering airspeed (the speed at which the airplane stalls at the limit load factor) has decreased, because the weight has decreased.
This is exactly how I've been understanding it. (lift/weight= Load factor)
i understand that a lighter aircraft is further away from the critical AOA vs the heavier aircraft. But from my point of view that doesn't describe why we can fly faster at a heavier weight.
The aircraft is not flying faster because of the heavier weight. If you look at almost any aircraft as you increase the weight you bring the CG further aft. This aft CG is the reason for us flying at a faster airspeed because as we know aft CG equals cruising at a lower angle of attack
The change in manuevering speed with weight happens regardless of any hypothetical CG shift. I am as surprised at your bringing it up as I would have been with your relating it to the phases of the moon.
