Polar742
Sorry, bemusing to myself.
What, if any, changes are likely to be seen as a result of this accident?
None.
Unless insurance or IATA forces the issue.
Make sure you don't drop kick Lithium Ion batteries before you put them on a pallet. As it has been said money is the determining factor and nothing will change as long as 3 or 4 people die.Sorry, bemusing to myself.
Don do your planes typically weigh out before space out? I ask because those new cans seem like they might weigh a lot. We all know that weight is money.Some changes where I work are full face masks rather than a mask and the "high school science class" goggles. Also, EVAS, which is a plastic bag thingy that fills with air and allows you to see the panel even with heavy smoke in the cockpit. Lastly, a new cargo container that is more fire resistant is in the works.
Not in a whale.
Same goes for you guys......nearest suitable piece of putdown place for your particular plane, airport or not. Because in some situations, trying to beat a fire to a suitable airport, the odds will be with the house at the outset and only getting worse.
Kelvin, you have an apu now. Give a guy an inch.... Jeesh!I can't speak for Don but us little guys usually bulk out before we weigh out. While the big boys are working with the new fire suppressant cans us little guys will just have to deal with it.
Indeed it would seem that the risk of an unplanned and unprepared ditching might be lower, in certain circumstances, than trying to go to an airport.
(not in ANY way criticizing this crew, of course—just gaming things out.)
Kelvin, you have an apu now. Give a guy an inch.... Jeesh!![]()
I find it cryptically amusing that the most common argument for "why Lithium?" Is "they are just that much more awesome." It appears that they are awesome at a lot of things! When was the last time you had an electrical emergency or a dead battery on the ground and thought wow Lithium would make the world so much better. I get it that Lithium is lighter for the energy. We're not talking wings here, though or seats or an entire fuselage. We're talking batteries and it's costing lives and tons of debate in the industry. The bean counters are winning.
For everything else, find a different way to transport them.
Agree.
No criticizing at all; just an observation and idea that many people don't ever consider as a possibility because it's never been thought of as a possibility in any kind of training.
I read a study that found an average of 18 minutes to get down for a successful outcome to an onboard fire. At my old job when I did almost all international, i would frequently point that out to new guys as we approached 30 west for their first time.
I agree. And what that means is that there may be situations where the plane is coming down to earth one way or another. The crew can choose to do it controlled to possibly a place that isn't an airport but is otherwise a landable surface (or even a not-fully-suitable airport); or they can gamble time getting to a suitable airport, and have the situation determine for them when the plane is coming out of the sky, out of their control. A completely crappy situation to be in ever, but one that's possible to find oneself in.
FINDINGS
60. The Captain’s inability to get oxygen through his mask was possibly the result of the oxygen hose
failure near the connector. The high thermal loading was conducted through the supplementary
oxygen stainless steel supply lines heating the supplementary oxygen directly affecting the flexible
hose connector causing the oxygen supply line to fail.
63. The oxygen requirement of the Captain became critical, the Captain removes the oxygen mask and
separate smoke goggles and leaves the seat to look for the supplementary oxygen. The Captain did
not return. The Captain was in distress locating the supplementary oxygen bottle and could not
locate it before being overcome by the fumes.
67. The FO had breathing difficulties as the aircraft descended as the normal mode function of the
mask supplies oxygen at a ratio to atmospheric, ambient air. The amount of oxygen supplied was
proportional to the cabin altitude.
