NTSB ADVISORY
National Transportation Safety Board
Washington, DC 20594
March 25, 2009
UPDATE ON NTSB INVESTIGATION INTO CRASH OF COLGAN AIR
DASH-8 NEAR BUFFALO, NEW YORK; PUBLIC HEARING SCHEDULED
In its continuing investigation into the crash of Colgan Air
flight 3407 in Clarence Center, New York, the National
Transportation Safety Board has released the following
factual information.
On February 12, 2009, about 10:17 p.m. Eastern Standard Time
(EST), a Colgan Air Inc., Bombardier Dash 8-Q400, N200WQ,
d.b.a. Continental Connection flight 3407, crashed during an
instrument approach to runway 23 at the Buffalo-Niagara
International Airport (BUF), Buffalo, New York. The crash
site was approximately 5 nautical miles northeast of the
airport in Clarence Center, New York, and mostly confined to
one residential house. The 4 crew members and 45 passengers
were fatally injured and the airplane was destroyed by
impact forces and post crash fire. There was one ground
fatality. Night visual meteorological conditions prevailed
at the time of the accident. The flight was a Code of
Federal Regulations (CFR) Part 121 scheduled passenger
flight from Liberty International Airport (EWR), Newark, New
Jersey to Buffalo.
The NTSB has voted to conduct a public hearing on this
accident. The hearing, which will be held May 12 - 14,
2009, at the NTSB's Board Room and Conference Center in
Washington, D.C., will cover a wide range of safety issues
including: icing effect on the airplane's performance, cold
weather operations, sterile cockpit rules, crew experience,
fatigue management, and stall recovery training. The public
hearing is part of the Safety Board's efforts to develop all
appropriate facts for the investigation.
"The tragedy of flight 3407 is the deadliest transportation
accident in the United States in more than 7 years," Acting
Chairman Mark V. Rosenker, who will chair the hearing, said.
"The circumstances of the crash have raised several issues
that go well beyond the widely discussed matter of airframe
icing, and we will explore these issues in our investigative
fact-finding hearing."
The hearing will be held "en banc," meaning that all Members
of the NTSB will sit on the Board of Inquiry. Parties that
will participate in the hearing will be announced at a later
time.
The aircraft wreckage has been moved from the accident site
to a secure location for follow-on inspections as may be
needed.
A preliminary examination of the airplane systems has
revealed no indication of pre-impact system failures or
anomalies. Investigators will perform additional
examinations on the dual distribution valves installed in
the airplane's de-ice system. The de-ice system removes ice
accumulation from the leading edges of the wings, horizontal
tail, and vertical tail through the use of pneumatic boots.
The dual distribution valves, which transfer air between
the main bleed air distribution ducts and the pneumatic
boots, were removed from the airplane for the examination.
The airplane maintenance records have been reviewed and no
significant findings have been identified at this time.
The ATC group has completed a review of recordings of
controller communications with the flight crew during the
accident flight and conducted interviews with air traffic
controllers on duty at the time of the accident. The group
has no further work planned at this time.
Further review of the weather conditions on the night of the
accident revealed the presence of variable periods of snow
and light to moderate icing during the accident airplane's
approach to the Buffalo airport.
Examination of the FDR data and preliminary evaluation of
airplane performance models shows that some ice accumulation
was likely present on the airplane prior to the initial
upset event, but that the airplane continued to respond as
expected to flight control inputs throughout the accident
flight. The FDR data also shows that the stall warning and
protection system, which includes the stick shaker and stick
pusher, activated at an airspeed and angle-of-attack (AOA)
consistent with that expected for normal operations when the
de-ice protection system is active. The airplane's stick
shaker will normally activate several knots above the actual
airplane stall speed in order to provide the flight crew
with a sufficient safety margin and time to initiate stall
recovery procedures. As a result of ice accumulation on the
airframe, an airplane's stall airspeed increases. To
account for this potential increase in stall speed in icing
conditions, the Dash 8-Q400's stall warning system activates
at a higher airspeed than normal when the de-ice system is
active in-flight to provide the flight crew with adequate
stall warning if ice accumulation is present.
Preliminary airplane performance modeling and simulation
efforts indicate that icing had a minimal impact on the
stall speed of the airplane. The FDR data indicates that
the stick shaker activated at 130 knots, which is consistent
with the de-ice system being engaged. FDR data further
indicate that when the stick shaker activated, there was a
25-pound pull force on the control column, followed by an up
elevator deflection and increase in pitch, angle of attack,
and Gs. The data indicate a likely separation of the
airflow over the wing and ensuing roll two seconds after the
stick shaker activated while the aircraft was slowing
through 125 knots and while at a flight load of 1.42 Gs.
The predicted stall speed at a load factor of 1 G would be
about 105 knots. Airplane performance work is continuing.
Since returning from on-scene, the Operations & Human
Performance group has conducted additional interviews with
flight crew members who had recently flown with and/or
provided instruction to the accident crew, as well as
personnel at Colgan Air responsible for providing training
of flight crews and overseeing the management and safety
operations at the airline. The group also conducted
interviews with FAA personnel responsible for oversight of
the Colgan certificate, which included the Principal
Operations Inspector (POI) and aircrew program manager for
the Dash 8 Q-400. The team has also continued its review of
documentation, manuals, and other guidance pertaining to the
operation of the Dash 8 Q-400 and training materials
provided to the Colgan Air flight crews.
The Operations & Human Performance group continues to
investigate and review documentation associated with the
flight crew's flight training history and professional
development during their employment at Colgan as well as
prior to joining the company.
Post-accident toxicological testing of the flight crew was
performed by the FAA Civil Aerospace Medical Institute
(CAMI) toxicology lab. Specimens taken from the first
officer were negative for alcohol, illicit substances, and a
wide range of prescription and over the counter medications.
Specimens taken from the captain were negative for alcohol
and illicit substances, and positive for diltiazem, a
prescription blood pressure medication that had been
reported to and approved for his use by the Federal Aviation
Administration.
The Safety Board is also examining several other areas
potentially related to the accident, including:
? The circumstances of a recent event involving a Dash
8-Q400, operated by Colgan Air, in which the
airplane's stick shaker activated during approach to
the Burlington International Airport (BTV) in
Burlington, Vermont. A preliminary review of the FDR
data from that flight shows the momentary onset of the
stick shaker during the approach phase of flight. The
airplane subsequently landed without incident. NTSB
investigators have conducted interviews with the
pilots and check airman on board this flight and will
continue to investigate the incident.
? Reports of airplane deviations resulting from
distortion of the instrument landing system (ILS)
signal for runway 23 at BUF. There is an existing
Notice to Airmen (NOTAM) related to this distortion
condition. To date, investigation into these reports
has not revealed any connection to the accident
flight.
-30-
Media Contact: Keith Holloway, (202) XXX-XXXX
