Thankfully we don't have that here. I have heard horror stories about quiet EPR settings.
Crash and burn...
A Lower Aft body heat ovheat warning is an absolute nightmare to deal with as the procedure is lengthy and bleed leak in that area can be disasterous.
The lower aft body area
includes the keel beam and the area above the aft cargo compartment. It contain heat sensing elements. A heat rise in any of these areas will light illuminate a warning light on the Flight Engineer's panel.
There is no fire bottle provided to combat an overheat condition. The only corrective action available is to reduce or turn off bleed air.
The procedure is a few pages long and calls for the crew to systematically eliminates vairous bleed sources and ducting as teh overheat source. The checklist is worked in sequences and requires pauses in specific areas to wait for the affect area to cool if isolated the correct bleed or duct.
The problem is if you are wrong the area still has very hot bleed air pouring into and if the keel beem fails it is game over.
