If I remember right, it boils down to whether your checkride was single pilot in something like a 501, or with a FO in a Bravo/Ultra etcI have a ce-500 PIC type rating with a limitation that says "second in command required". I have several co workers with the same type rating but without the limitation. They don't have the single pilot exemption. Is there a reason why mine has the limitation?
If you do a recurrent in a 501 you can demonstrate single pilot proficiency and have that removed
Thanks! I'd love to know what you find out. Does that mean you're single pilot qualified?Strange...I have no such limitation on my CE-500 type, even though I took my checkride with an SIC and never had a need to operate single pilot. For what it's worth, I did my initial type in the Citation V course at FlightSafety in Long Beach.
I'll dig around a little and report back if I can figure out why I don't have the limitation.
I read that too but I took my type ride in a citation II at CAE which is a 550 right? Maybe they just screwed up my paperwork. I guess it doesn't matter one way or the other but at least I know I was on the right track with my research.I think I found an answer. Had to dig in to the FAA's General Aviation Airman Designee Handbook. Here is a link:
Look at Section 12, 87(b) Cessna 500 Series Airplanes.
If you took your checkride in a 501 or 551 (the single pilot certified models of the CE-500 type), you can choose to take your checkride as either single pilot or with an SIC.
If you opt for using an SIC, you receive the "SIC Required" limitation with your CE-500 type.
If you take your checkride in any of the aircraft which normally require a crew of two (such as the 500/550/560 II/V/Ultra/Bravo/Encore, etc) they don't say "SIC Required" because it's understood you used an SIC to receive the type.
Thanks for making me dig!
I did, but so did my coworkers. I don't have a need for a single pilot exemption. I was looking at the pilot's information for the plane that went down in Georgia. He didn't have the limitation so it got me wondering if he was single pilot qualified.Did you hand a right seater on your checkride? It so, that’s why it’s there.
i teach on a different program at CAE, but we cannot do single pilot types as the first and only check. Could be out fed or curriculum, idr. But if you want a single pilot you have to go through the motions as you would for an initial type, and then a single pilot checkride. That may or may not have training attached to it
Sounds like fun.I have one better for you. I possess a CE-525s type. Single pilot certified. However I also have the second in command required for CE-500. Its all based on how you do your type ride. You must demonstrate for flight safety/CAE (aka FAA) that you can do the required procedures without a copilot.
I had to do a V1 cut no autopilot approach to minimums and make sure to run all checklists to receive my S type
Well something is not right with your digging or my license. Took my initial in a 560 Ultra and have the SIC required on my license. If your digging is correct then I need to have a talk with FSI.I think I found an answer. Had to dig in to the FAA's General Aviation Airman Designee Handbook. Here is a link:
