Type rating limitations.
tlove482
I have a ce-500 PIC type rating with a limitation that says "second in command required". I have several co workers with the same type rating but without the limitation. They don't have the single pilot exemption. Is there a reason why mine has the limitation?
If I remember right, it boils down to whether your checkride was single pilot in something like a 501, or with a FO in a Bravo/Ultra etc
If you do a recurrent in a 501 you can demonstrate single pilot proficiency and have that removed
No limitation on mine. But my FAA check, I had to fly the thing single pilot for everything. No biggie, just like a T-37 jet with a passenger cabin and flying it single pilot.
from the ATC ACS...it’s another type ride.
Strange...I have no such limitation on my CE-500 type, even though I took my checkride with an SIC and never had a need to operate single pilot. For what it's worth, I did my initial type in the Citation V course at FlightSafety in Long Beach.
I'll dig around a little and report back if I can figure out why I don't have the limitation.
It was in a 550 for all of us, yet I'm the only one with a limitation. No one did a single pilot ride.
Thanks! I'd love to know what you find out. Does that mean you're single pilot qualified?
I think I found an answer. Had to dig in to the FAA's General Aviation Airman Designee Handbook. Here is a link:
Look at Section 12, 87(b) Cessna 500 Series Airplanes.
If you took your checkride in a 501 or 551 (the single pilot certified models of the CE-500 type), you can choose to take your checkride as either single pilot or with an SIC.
If you opt for using an SIC, you receive the "SIC Required" limitation with your CE-500 type.
If you take your checkride in any of the aircraft which normally require a crew of two (such as the 500/550/560 II/V/Ultra/Bravo/Encore, etc) they don't say "SIC Required" because it's understood you used an SIC to receive the type.
Thanks for making me dig!
I read that too but I took my type ride in a citation II at CAE which is a 550 right? Maybe they just screwed up my paperwork. I guess it doesn't matter one way or the other but at least I know I was on the right track with my research.
No, although it might look that way at first. Never been trained for it nor received a waiver.
Anyone who claims to be single pilot qualified in any CE-500 should have clear documentation to prove it, either in the form of a waiver (which they must carry with them when operating single pilot) or proof they took a checkride single pilot in the 501/551, which would then give them a CE-500 type but only authorize them to fly the specific model single pilot.
Yeah, I'd guess they goofed up the paperwork. Although it doesn't affect anything. You'd need an SIC with you anyway, the same as your coworkers. Don't let your coworkers assume they can fly a CE-500 single pilot since they don't have a limitation like you.
As JeppUpdater was saying, this is a really confusing type and what's printed on one's pilot certificate only tells a fraction of the story.
My company flies the II, V, and Ultra. I just became a check airman on these things and learned I can conduct checkrides in the 560 (V and Ultra) with oral differences to the 550, but not the other way around. Flying a 550 and talking about the 560 would be totally illegal for me. Why? I have no idea. Because FAA.
Did you hand a right seater on your checkride? It so, that’s why it’s there.
i teach on a different program at CAE, but we cannot do single pilot types as the first and only check. Could be out fed or curriculum, idr. But if you want a single pilot you have to go through the motions as you would for an initial type, and then a single pilot checkride. That may or may not have training attached to it
I have one better for you. I possess a CE-525s type. Single pilot certified. However I also have the second in command required for CE-500. Its all based on how you do your type ride. You must demonstrate for flight safety/CAE (aka FAA) that you can do the required procedures without a copilot.
I had to do a V1 cut no autopilot approach to minimums and make sure to run all checklists to receive my S type
I did, but so did my coworkers. I don't have a need for a single pilot exemption. I was looking at the pilot's information for the plane that went down in Georgia. He didn't have the limitation so it got me wondering if he was single pilot qualified.
Sounds like fun.
Well something is not right with your digging or my license. Took my initial in a 560 Ultra and have the SIC required on my license. If your digging is correct then I need to have a talk with FSI.
Interesting.
Did you read the original source I linked to, and if so, what do you think?
It's possible I'm misunderstanding something or maybe more recent guidance has come out I'm not aware of. I did my type in early 2017, if that makes any difference.
If you talk to FlightSafety I'd love to hear what they say. It doesn't matter in real world operations...we still need SICs regardless of if the limitation is printed or not. But it would be interesting to hear how FlightSafety explains it.
While digging through the Citation 500 series FSB report this evening on an unrelated search for training information, I ran across this little gem...
2.2.1 Pilot Type Rating. Practical tests conducted in Cessna model 500, 550, S550, 552 and 560 are required to be conducted with two pilots and satisfactory completion will result in a CE-500 pilot type rating on the pilots temporary airmen certificate, with the limitation “CE-500 Second in Command Required.” The satisfactory accomplishment of the CE-500 practical test utilizing a second in command will be recorded in the applicant’s logbook in accordance with FAA Order 8900.1 Volume 5, Chapter 2.
It seems the General Aviation Airman Designee Handbook directly contradicts guidance from the Flight Standardization Board Report.
Does one take priority over the other? I have no idea. They both seem to be fairly authoritative guidance directly from high-level FAA offices.
This might explain some of the confusion over pilots going through identical training/checking and receiving different certificates. Even the FAA can't get on the same page about how to document it.
