Training In Diamond Aircraft
The DA-20 floats worse than any other plane I have ever flown.
It doesn't float that bad if you actually approach at the speeds recommended in the AFM. If you approach at 65, there is considerable float. Approach at 55, much less float. I love flying the DA20-C1s, but wish they were a little more stable when doing stalls. (Students tend to scare themselves in them the first couple times doing stalls or slow flight....)
they break constantly
Our school has 3 twinstars, all of them are currently offline due to maintenance. Of course, hitting a deer with one will have that affect.....
BTW, what is the story with the DA20 that your school put into the ground hard enough to set off the ELT? I heard it was a student pilot on his first trip out of the pattern? Or is my info totally wrong? I was flying that day with a student and heard all of the excitement on the radio.
Totally wrong, it is a DA 20 with that retarded aneroid fuel pump, the engine quit and would not restart; we have had nothing but problems with that plane since the day it showed up. Diamond sent us a new fuel pump like a week prior that was supposed to fix the problems.
The FAA guys actually complimented him on doing everything right on the forced landing. He set it down really soft, but then ran into a ditch. Good riddance to that airplane; and nobody got hurt.
I stand corrected.... It just goes to show you can rarely believe what you hear. I don't know that I would have done so well my first solo trip out of the pattern. Tell him kudos for me.
BTW, saw something pretty interesting today at PVU. This guy was taking off in a experimental jet, (looked like a surplus military trainer) He was cleared for t/o 13, I was holding short number two in sequence when all of the sudden the tower tells the guy cleared to land immediately any runway. There was no response, then the tower says runway 18 available if needed. The guy had forgotten to latch the canopy and it ripped off and flew into the air and landed on the runway behind him. Must have been quite a surprise. He came around and landed safely though. That was the only time I have ever been told to turn around and taxi back to runway 18 when holding short at 13. Made for an interesting day.
Tweet.............Glad to see you made it!
Good luck in Illinois when you get here. You are hitting it just right! The weather is cooling down and stabilizing, most of the crops are down and they are just starting to get into chase mode!:D In fact on Tuesday, a friend droped a 160" eight pt. that dressed out at 250lbs.:drool:
Be sure to send me some pictures of your trip! I will be out on Halloween for sure, the big ones are always on the move on that day! Also, if you feel the need to try a new broad head or arrow rest let me know, I can get you into some NAP equipment (kind of know someone;))!
As far as Air New Zealand goes.................keep me posted! You are really making me jealous!
Sorry about the hijack folks................back to topic!
Hey PGA,
I finally found my way over…
FWIW I have been instructing in the DA-20 for the past several years here at the AF Academy. Although, now that the contract with ERAU has ended, I will be flying something else.
I found the DA-20 to be a fun little airplane with good characteristics. It did have some lateral instability but nothing you couldn’t overcome. It was also very under-powered here at our altitudes. We routinely have DA’s over 9500’ during the summer months so we had to be very careful with our operations. For the record when I flew one back to the Chicago area a few summers ago I was amazed at much better it performed at lower altitudes.
As others have mentioned it is based on a motor glider so it is a very clean aircraft with a very high glide ratio compared to other trainers. As a result you will need to keep an eye on / manage your energy a bit more then a Cessna.
And as far as the stick goes…no worries there…it will be a seamless transition back and forth. I would actually much prefer to fly a stick myself!!
With all that said I would have no problem teaching my wife and kids to fly in a DA-20.
Cheers,
PS I leave to hunt IL tomorrow and I got some good news from a buddy at Air New Zealand…all is right with the world!! Hope your season is going well.
