bob loblaw
NJA_Capt said:Actually, it WAS in the AFM as an approved entry. (ie. crosswind and turn left to enter downwind)
The AFM used to state that you were allowed to cross midfield at Traffic Pattern Altitude (and giving way to traffic already on downwind), and turn left (left traffic) to enter the downwind.
Adding 500 feet is a dangerous practice because is places you in the turbine aircrafts pattern altitude (1500 AGL).
It is a lot safer to cross at pattern alt and turn left, than to cross and do a right 270 in front of other arriving aircraft. There is no difference in the "alternate" entry than when you are doing laps in the pattern. When you are doing circuits, do you exit the pattern and re-enter on the 45? Or do you turn crosswind to downwind? (Like I don't know the answer).
Either way, be safe out there.
PS....I never circled the windsock. I just fly a downwind leg and look at it. If the wind favors the runway you picked...land. If not, transition to the other downwind and land on that runway.
You want to add 500 feet to the pattern altitude if you cross over the airport at a 90 degree angle to the downwind and teardrop to enter the 45. You don't want to add 500 feet if you cross midfield at pattern altitude and turn left to join the downwind. This technique should be done at pattern altitude.
