So, to close this out...
I appreciate all the of recommendations. There was some good advice in the thread. And because I like gadgets and stuff, I decided to get two flashlights.
I picked up a JetBeam E10R and then something that WASN'T recommended here but I found while searching....a NiteCore TUP.
I decided that variable brightness was a good idea, (that was a good tip from
@BEEF SUPREME - learned this first-hand when I was trying to start up a sim from "cold dark airplane" mode and couldn't see a damned thing) and also wanted something not-too-expensive but not junk either
I had high hopes for the JetBeam - compact size, good price, variable features. However, the on/off button is unreliable. For a few minutes, I thought maybe it was defective. Then when I got it working I paid closer attention to the badly-translated manual, realized that
part of it was user error. So I can now turn the thing on and off with proper technique....but it still doesn't always want to turn on or off even with proper technique. So it's likely going to be the backup. I'm too lazy and hamstrung for transportation right now to bother with returning it. It mostly works.
The Nitecore TUP was a pleasant surprise. SUPER compact, variable brightness through wide ranges, rechargeable, and RIDICULOUSLY bright (1250 lumens) on the highest setting. You can feel heat coming off the lens when it's that bright.
Probably going to get another one to have around. But, these should do for the time being.
