The quote I listed above was taken straight out of the FOM, and it is definitely taught that way in groundschool. It seems pretty clear to me....what's listed on the 10-9A is irrelevant unless it depicts mins higher than the standard 1 SM. If that's the wrong way to do it, it wouldn't be a matter of teaching it wrong, it would have to be erroneously written in the FOM, which I doubt since I'm sure some Fed has gone over it with a fine toothed comb. I'm sure we would'be been busted for it already if it were indeed an illegal practice. But hey, stranger things have happened I guess. Those 10-9 pages are not tailored in our subscriptions.
Here's the process we have to go through when trying to figure out we can T/O in low visibility. First we make sure we have a T/O alternate, then we look at the 10-9A. If the mins listed on there are no more restrictive than 1 SM visibility, we go to the next step.
Is visibility at least RVR 1600 or 1/4 mile? If yes, then do you have HIRL, or CL lights, or serviceable RCLM? If yes, then you may takeoff.
Otherwise:
Is visibility at least RVR 1200 on all RVR reports (must have at least 2, far-end does not count)? If yes, and it's daytime, then do you have RCLM, or HIRL, or CL lights? If it's night, then do you have HIRL or CL lights? If yes, then you may take off.
Otherwise:
Is visibility at least RVR 1000? If yes, do you have CL lights or "HIRL AND RCLM"? If yes, then you may take off.
Otherwise:
Is visibility at least at RVR 600? If yes, do you have HIRL AND CL lights? If yes, then you may take off.
Otherwise:
You may not takeoff.
It's also wise to double check that you can actually see at least 3 Centerline markings if you takeoff in 600 RVR. There are 200 feet from the beginning of one marking to the beginning of the next one. You can also check that you can see 12 centerline lights since they are spaced in 50 foot intervals.
Again all of this applies to my operation only, I have no idea how it works anywhere else. This is a lot to remember so we are required to carry a document around which outlines this process until it is incoporated into our publications (the required equipement for each scenario was recently revised).
