Personally, I don't think the 140 is a good plane to wheel land for much other than kicks and giggles. That's my personal opinion. I'm sure there are 140 pilots who would disagree.
Meh, I disagree, but I'm not a 140 pilot. Many many tailwheel airplanes have stiff spring-steel main gear, including all the American Champion/Bellanca products (Citabrias, Super Ds, etc). You better believe that you have to finesse the mains onto the ground with almost no sink rate to avoid bouncing 5+ ft in the air, but it is doable.
jrh said:
Pushing forward on the yoke after a bounce, with anything other than excellent timing, has a tendency to increase the bouncing oscillations, rather than damp them out, like some other tailwheel gear designs.
Good god man! This should never be a recommendation in any tailwheel plane! If you bounce, you have two options: Transition to a 3-point and let the airplane settle, or go around. It was burned into my head not to try and push the mains back onto the ground after a bounce because of pilot-induced oscillation, and I've
still made the mistake (recently!). Speaking of groundloops (and prop strikes), that's a great way to initiate them.
In crosswinds, I much prefer doing a one-wheel wheel landing and keeping the tail up for as long as possible to maintain rudder authority and directional control while the speed bleeds off. The downside to this is it uses up a LOT of runway. So certainly there are exceptions to the rule when landing on shorter runways, and I wouldn't try to wheel land on anything shorter than about 2700 ft (don't ask why I chose this number so precisely
Could be different on the C140, but in a 7ECA/7GCAA the tailwheel is spring-loaded to the rudder, and calling it completely "steerable" would be a bit generous. I also don't like landing in a "
tail low" attitude, because that was burned into my head during training as being the least rudder-effective and most unstable attitude you can be in. I'd rather be 3-pointed down with the tailwheel on the ground, or up on the mains with the fuselage parallel to the ground, rather than have the tailwheel 6" to 1' above it. I've heard the reason everyone hates the T-6 and ground loops it so much is because of this - it's tail-heavy and always wants to be in a tail-low attitude.
I think what you're talking about is the "two-point" landing, where you land the upwind main and the tailwheel, with the downwind main still in the air. I've heard that's a doable and appropriate crosswind technique (I've barely tried it so I can't speak from experience), but if you try to do a true three point in a gusty crosswind without getting the upwind wing down, you're going to side load and swerve all over the place... and probably not have much directional control to save yourself as the airplane tries to weather-vane (especially in a Citabria where those tailwheel/rudder springs only help you so much). Again, ask me how I know.
