Ok I have a student that is an ex military pilot who hasnt flown in 20 years, he has 1600 hours, but all in a twin engine jet with a commercial license.
I havnt found it in the FAR's, but can I do a private pilot add-on? or does it have to be a commercial add-on? Can I sign him off to solo? or will he need a student pilots license? Do I need to give him a BFR before his checkride? before he solo's? or even at all?
Thanks
To be precise, he hold a commercial certificate, not a license. In a case such as this, being precise is important because as you read the regulations the words category, class, and many others take on extra importance in ensuring the person meets the requirements for the test.
Before your student can solo, he needs an endorsement in his logbook just as you would place in any other student's logbook. He does not need a student certificate or the endorsement that you would normally make on the student certificate. He will need a current medical certificate before solo, again, just as any other student would (unless you are using light sport).
Your student does not need a flight review in order to take the practical test (check ride). The student will be the PIC during the practical test whether he has a flight review or not, just the same as your more conventional students.
Do carefully read the
regulations for eligibility and ensure every I is dotted and each T is crossed. Do not assume the student knows anything or can do anything until you verify it yourself.
His practical test will be from the Private Pilot PTS. Look at the "Additional Rating Task Table" in the PTS. That shows the tasks on which he MUST be tested. At the examiner's discretion, they CAN test on any or all tasks above and beyond the required minimum. However, the common experience is that the examiner will limit the test to the required items and any tasks beyond that are just those that would occur normally (for example, Task D of Area of Operation II is Taxiing, which is not required, but is going to be demonstrated in normal operation).
