Right, and based on the AC43.13 (acceptable data) section on electrical wiring, I bet you would find that a breaker switch is, in fact, acceptable. For the record, I never advocated installing a separate switch, just replacing the existing breaker with a switchable one. I'm not sure what your involvement level with maintenance is, or why you're so wrapped up in this when I'm fairly sure you don't deal with this stuff on a daily basis, but you'll find that the FAA does, in fact, give a mech quite a bit of freedom in creating minor alterations, using approved parts, in accordance with AC43.13. Here is another example- per at least one FSDO, you can replace a standard landing light with a LED one with simply a logbook entry, provided the electrical load analysis and the existing wire size accommodate it because, once again, you are replacing a standard electrical part with one of the same functionality, using approved parts. Note that this mod often does actually require and STC because the maker of the LED lights owns an STC for their installation.
Nope. The ones I have experience with (172, DA42) do not.
