The amount of energy you have on touchdown is the amount of energy you have to get rid of in the roll-out. Remember that the energy goes up by the square of your speed - meaning double the speed and you quadruple the energy. Remember also, stall speed varies with weight, power setting, flap setting, ground effect, and that's the "slowest possible touchdown speed" where you're in control. Depending on how short the strip is, and how comfortable you are, an approach speed of around 1.1Vso may be better suited in the last part of the approach. I'd often have two power settings in my head, the one that would give me 1.3 Vso - ish, and the one that would put me right above stall and feel it on the rest of the way from there and transition to this second power setting around 200' AGL. I remember in the 206 coming in with just enough airspeed left to be able to able to flare and feeling the stall buffet an instant before the mains touch - that's the speed to have the shortest possible ground run.
The book value is exactly that, but the airplane can be flown all the way into the stall if necessary, if I recall, 1.3 Vso is the "max" shortfield speed, not the minimum.
