lilrkt
Keep in mind as well that at many uncontrolled airports, if you have someone call in the emergency crews, you will have to pay several hundred dollars for them to come out. If there is truely an emergency then insurance will probably pick it up, but if not you will be stuck with that bill. Judgement call. I believe that the way you landed, even if the front gear did collapse, it would hurt nothing but the prop, engine and front end. You are going too slow at that point to roll if you stay on the runway. CHances are that even if you slid off, you would just come to a stop. I would have cut the engine though. THere was no opportunity for a go around at that point, you should at least try to save the engine.
