The big commutable ops up there are either ERA or Grant. You'd be right in there sweet spot as far as hours but unless they're hurting for pilots just emailing resumes up to the great white north probably won't do you a whole lot of good.
On the other hand if you were instructing in ANC you'd have a much better opportunity to find yourself in a bush position.
Also keep on mind that you won't get any multi time out there, so if you only have 55 multi you'll have to find another way to build up to whatever mins your regional of choice requires.
All that said, if you want a little adventure and fun (and yes, there is lots of fun flying to be had in AK) by all means go for it. Spend a year or two, but unless you want to be an AK lifer don't spend too much more than that.
If you want to get to a regional (which at the right regional aren't all that bad QOL wise) get your butt over to AmFlight, do your time in a Navajo, get some turbine PIC in the 99, then hope SkyWest is hiring then.
Check out the interviews section of oddballpilot.com for some good intel on ERA.
