legal: sure, just don't get in a situation where the FAA may use it against you, as Doug has suggested
wise: if you can use your arms and feet, while driving on the ground, and avoiding stuff, crossing a hold line, etc. I'm not really sure it saves all that much time though. It is only 'wise' on aircraft that can't hold a plane for a runup.
recommended: kinda goes along with wise. There are some aircraft where breaks simply will not hold the plane in a static runup. So do it on the roll. Either on a taxiway out, with no one around, or on the runway. Older aircraft with mechanical brakes can be considered to almost not have any brakes at all. I always have fun trying to hold the thundering 85HP engine in the champ I've been flying lately, in the runup area. If I was on a grass field, I'd do it on the roll. At a busy airport, don't position with anyone in front of you, as it starts to creap forward. Same thing if doing a runup on the roll. Make sure you are not taxiing right behind someone!
