Run-up while taxiing?
Uhhh... No,No, and No. For the C172 you need to set the parking brake and power up to 1800 rpms then check the mags. It would be hard to do that while taxing.
If you don't mind getting airborne while doing it..
First of all, the answers to your questions ON THE RECORD are NO, NO, and NO from me as well. However, this is something that many multiengine drivers are guilty of, including myself. Sometimes it's too time consuming and costly to do a full static run up in a multi. However, this kind of behavior is foolish, because sooner or later it will bite your in the @ss! Personally, i would say, don't even start.
Not as a beginner!
But most pro's do the runup whil taxiing these days. Especially charter. These people are paying big bucks to get somewhere in a hurry and as a chief pilot, I like to see the plane MOVING. It irks me a little to see a pilot start up both engines and then sit there going through checklists and copying clearances, all the while burning up fuel and time.
At least taxi out to the movement area, where you can get (and need) a clearance from ground. As for the actual runup?
1) The 1500 rpm prop feather check (for most twins) can be done while taxiing.
2) A low rpm mag check (1700 or less) is usually doable too.
3) Higher rpm checks can be done while holding short of intervening runways or in the holding area (sometimes called a run-up area by instructor pilots.)
Everything else can and should be done while taxiing. Flight controls, cowl flaps, trim tabs, checking flight instruments (plane is supposed to be moving and turning anyway) can also be done while moving.
2 pet peeves though:
1) Don't taxi too fast. Once the plane is moving you are underway, logging the time and the passenger(s) will be happy. The AIM recommends "a fast walk."
2) Don't slam on the brakes as soon as you start! That's a "new CFI" trick that is not too impressive for passengers. You can do a brake check by applying gentle pressure and see if the plane slows down. You can even slowly come to a complete stop without throwing everything in the plane forward, but it is sufficient to ensure that the brakes work. Do NOT jam your feet on those brakes!
I've had pilots do that to me on charter check rides. Unbelievable.
And then all of a sudden !!!WHAM!!! you blow past a taxiway and have a runway incursion. Then the FAA is wondering what distracted you during taxi...
And that is why I prefer to do my run-up during the takeoff roll.
Rolling run-ups are not really a good idea, the only time I do them is when I am flying with a pilot I trust (he taxi, I do the checklist), and an airport I know!
Man, drives me crazy when pilots try to do that!!!! It's the personification of UNSAFE!!!!
What's the hurry? I can do an engine run up in 20 seconds. If you're in that much of a hurry, you need to reschedule whatever it is that you're going to.
Doing a run-up while taxiing is about as smart as doing your weight and balance enroute....
I'm with you. I've got a friend who flies around the CEO and officers of a very large company. He said that the CEO told him, you're in charge here, if you say we don't go, then that's it, and if you need for us to wait, we wait. And if anyone fusses at you, tell them that I said so.
So, if the CEO of a company can wait a few minutes for my friend to go through his checklist, so can anyone else.
I seriously hope you're not relying on the parking brake to hold you during the run-up ... feet should be on the brakes applying pressure to hold you there. Never rely on the parking-brake.
And as far as the "brake test" right after startup ... if you're holding the brakes like you (generic you) should be doing -- instead of the parking brake -- you already know if the brakes are working because you're staying in one spot as the engine spools up!
I'll agree with the "No" on "recommended".
I'll even agree with a "generally No" on "wise".
But "legal"? I can't find one thing that makes a rolling run-up contrary to rule or regulation, other that maybe that it would be considered careless/reckless operation if you had a mishap.
After all, take that 182, stick it on floats, and all of a sudden running up on the move becomes normal operating procedure.
Well, while it may be "legal," what happens when you get that runway incursion that Doug was talking about?
That ain't gonna look good.
That is the FAA catch-all.
Because if you're conducting a rolling runup and anything happens, I can virtually guarantee you'll get slapped with "Careless and Wreckless Operation of an Aircraft".
There were some times when we'd have to redo our 'first flight' checks in the Beech 1900 and the passengers really didn't care. People are lot more nervous about flying than one would think and if they think it's all about safety, they're pretty happy to take the time.
I've had my tangles with the FAA while a CFI and believe me, lots of stuff is open to interpretation.
And if a passenger does complain that you are taking the time, just explain how it is better to discover engine problems on the ground than in the air. 99% of the people will understand and leave you alone, and you probably don't want the other 1% on board anyway.
My $0.02.
MF
in a single pilot situation especially, I think a rolling runup is not the greatest of ideas. Since you are trying to run checklists at the same time, your attention is being divided amongst too many tasks. Do you read a book as you are driving down the interstate?
From a time/money vs. safety standpoint, safety should always be the priority.
Sarah
[/ QUOTE ]No it won't (which is why it's not recommended or generally smart). But that runway incursion won't look any better if you weren't doing a rolling run-up.
You're right. But I think the point that Doug was trying to make -- and he'll just edit my post if I'm wrong here -- is that if you're distracted because you're doing a rolling run up, you're far more likely to do something that you're going to have to explain to the FAA.
Kind of like talking on your cell phone when you're driving, you know?
[/ QUOTE ]I agree. My quibble was with using the technical term "illegal" loosely. The fact that a practice or distraction contributes to a careless and reckless operation situation or another violation doesn't make the practice or distraction "illegal".
Talking to your passenger about the flight while taxiing can cause a runway incursion. That doesn't make "talking to passengers" illegal.
I think that if you do it on the roll sometime prior to rotation you should be cool... j/k
If you don't have a couple of minutes to spare to follow the proceedures, then you can't really blame anyone but yourself when you create a new hole in the ground.
Dave
