Sisson2011
I know at almost every airport you are suppose to do your run up at the end of the runway before departure.  However, what if it is at a primary class C or B airport.  Do you just tell ground when you taxi you still need to do your run up so they know, or maybe they have a specific location for you to do it at?
Also, when you call a tower airport with an AWOS/ASOS (not ATIS).. how do you report the weather... at my local airport we say "with the numbers", however, I have also hear, "have the weather", or "got the ASOS (AWOS)". Is there generally a correct way or is all acceptable?
