Inverted
mmmmmm wine
YessirFCS?
YessirFCS?
lol very serendipitous as first listen was yesterday!Yessir
Thanks for listening! It's terrible so sorry you are putting yourself through that lol.lol very serendipitous as first listen was yesterday!
Oh no, I’ve wasted 2 minutes on worse things!Thanks for listening! It's terrible so sorry you are putting yourself through that lol.
That's what my wife says!Oh no, I’ve wasted 2 minutes on worse things!![]()
Cause y’all tripping on the slightest things that no one’s else is tripping about:That's what my wife says!
I won't say that a conclusion is arrived to off the cuff but the funnel of investigative logic tends to go toward pilot error.
Friday 4/25 after the airshow rehearsal
A tradition dating back to the RAF when a fighter pilot didn't return from a mission a brother would play the piano while the other pilots wished him well. One day the piano player himself didn't return and the bother pilots decided that no one would ever play that piano ever again.
Welp, that would do it. Sucks.
My God, if he just would have set it down. The difference between life and death was a couple hundred feet of runway.
Yes, I understand. The way the report reads he leveled off and flew down the runway a bit. And then abruptly pitched up. Meaning he was in control until he wasn’t? Or was he already in trouble as he came over the numbers?It's a bit more complex than that. That MXS was basically divergent in pitch. Very aft CG in normal config. If that elevator got stuck and he had to unjam it, the pitching moment would be insane.
speculation only, but it certainly doesn’t look as though there is any secondary retention method such as safety wire or pin. Who knows if the internal threads have a metal or nylon lock like a locking nut or nutplate would, or if it simply relied on torque possibly with the help of loctite to retain it. In retrospect it’s certainly the kind of place you would want a secondary retention method beyond just proper torque (which can be tricky as is with a slot head, again, in retrospect you’d probably want a torx or Allen or something).I’m curious about the design of the plug but I’m sure the NTSB will answer any and all questions in their final.
Hardly seems like a brand issue if it ends up being related to an aftermarket modThe question is what damage this does to the MX brand. To lose an icon like him on something structural. What a shame.
