Joe Gremlin
How would one know that you were joking? I didn't see any of theseWow, really?
Light piston engines have an enrichment feature built in when the throttle is full forward. This is to add extra fuel so that in worst case conditions, hot engine, hot air, sea level, the detonation margin is increased and extra fuel helps to keep CHTs lower than they would be otherwise. You bypass this feature if you takeoff with less than full power. Is this a big deal? In many cases no but I would not do it without an engine monitor that monitors all CHTs.
How would one know that you were joking? I didn't see any of these![]()
:joke:in your post. So how exactly would anyone know you were only kidding? How exactly would a 50 hour private pilot who might be reading the forum know you were joking?
So that means I should assume just because someone has CFI after their name, they clearly understand the basics of how aircraft engines work? There was a time when I used to believe that. But I've flown with far too many buffoons that had a CFI ticket and absolutely no idea what happens on the other side of the firewall to make such an assumption any more.Because your learn the difference between a car engine and an airplane engine pre-solo and this guy has "flight instructor" in his profile.
OK that would have been funny, if I had had just a little more SA...
If it was a joke, and I'm not sure that it was, then it's an example of Poe's Law. There are many flight instructors and highly experienced pilots who use the same reasoning, so if a 60 hour student didn't take it seriously, then it's more likely due to his lack of experience.
Regardless of whether it was a joke or not, many readers aren't likely to interpret it that way, so if the view goes unchallenged, they walk away thinking there is merit to the idea.
Is Poe's Law an example of Poe's Law. After reading that explanation I'm not sure if Poe's Law is a real "Law" or just a parody of other "Laws".
I knew that the info was inaccurate, but I had heard this discussed before in a room a long time ago, and even asked one of my mentors, who owns a Flight School and is an A&P and is an amazing mechanic. He said run 'em at full power they're made for it. It was only then that it was clarified for me.I don't know what you mean by "real law", but it's a very commonly cited observation in internet discussion groups after a bizarre post. There is no conceivable idea too stupid to be sincerely believed by at least one member of society.
Unlike Murphy's law, and many other truisms or adages, I have never heard of it before. Sounds as if some guy on the internet named "Poe" said something and eponymously named it "Poe's Law". Not sure whether its supposed to be profound or parody.I don't know what you mean by "real law", but it's a very commonly cited observation in internet discussion groups after a bizarre post. There is no conceivable idea too stupid to be sincerely believed by at least one member of society.
I figured with all the flame bait floating around, i would throw my own into the mix...
You can't really expect any useful discussion to happen. If an instructor can't be bothered crack open the POH/AFM and read the normal operations for the aircraft he is teaching in, obviously, said instructor shouldn't be instructing. Same with a 60 hour private pilot or pre solo student.
Actually, if it's not in the Lav, I fully expect useful discussion to happen. I read this thread when there was only one or two responses, and considered closing it since he stated it was flame bait. On second thought, I realized that was a funny and off handed way to start a discussion.When the OP begins the thread with:
I agree with the sentiment, but when you have probably half the instructors in the country teaching no oversquare power settings, can you really say these people shouldn't be instructing? I think there is some interesting psychology that occurs here and I'm sure it's not limited to aviation. But it seems that when someone gives you a rule which is more restrictive than one you have from authority, you tend to give it some credibility, unless the authority directly contradicts it.
While very few instructors are teaching partial power takeoffs, almost all of them advocate a power reduction immediately after takeoff in aircraft with a constant speed prop, and the only source of this technique is from flight instructors. Once someone gets it into his mind he should do this, the lack of a specific recommendation for the technique in the POH is not sufficient to eliminate the habit, at least for most people.
My own view is that a great many pilots would benefit from throwing away what they were taught about flying a particular airplane and start from scratch using the POH.
Think for yourself. Following the POH or the CFI mindlessly does you no good what-so-ever.
