ASpilot2be
Qbicle seat warmer
Honestly Skagway isnt too bad. There is just a rivalry of sorts between Haines and Skagway.We didn't choose it, it was assigned as part of the gig. Had I to do this over again I'd stay at PAJN.
There just isn't anything to do here if you don't smoke weed.Honestly Skagway isnt too bad. There is just a rivalry of sorts between Haines and Skagway.![]()
:laff: That explains the stench in Haines when the wind blows from Skagway.There just isn't anything to do here if you don't smoke weed.
EDIT: I also flew a baron for the first time today... AND landed it below blue line!!! GASP!!!!
IMO, It's a legitimate training technique, so long as it's carefully planned and you have a means to compute takeoff and landing data. Pilots who fly nothing but sea level need to have an understanding of what to expect in high density altitude conditions.
Besides, in jet aircraft, reduced power settings are standard operating procedure when takeoff rated thrust isn't required due to reduction on engine wear & tear and noise abatement.
Chuck Norris doesn't use power on takeoff.
I don't like to push the envelope. Its not good to drive your car with the gas pedal to the max, so why would it be good in an airplane? I'll stick to 3/4 power takeoffs, thank you very much.
Agreed...:yeahthat:Automotive engines are not designed to be operated at max RPM. Aircraft engines are. Therefore taking off at max RPM is not pushing the envelope. Its doing exactly what the engine was designed from the ground up to do.
Automotive engines are not designed to be operated at max RPM. Aircraft engines are. Therefore taking off at max RPM is not pushing the envelope. Its doing exactly what the engine was designed from the ground up to do. I'm not saying there's anything wrong with using reduced power for takeoff if you've got the runway for it. But your logic simply doesn't hold water.
It might be a joke, I'll give you that. But I'll have disagree with you on it being a good joke. If it were a good joke, it would have been obvious that it was a joke.Haha everyone is so wound up with all this technique arguing they can't even spot a good joke![]()
