CoffeeIcePapers
Well-Hung Member
I'm not a GA MEI however I am a Part 121 check airman for a major airline flying the MD-80. We occasionally get to do actual "pilot trainers" in the real airplane. I can tell you the quickest was to get terminated from my company would be to actually shut off a fuel lever to simulate an engine failure! I actually cannot imagine ever needing to do this.
I understand the need to feather an engine and restart it for training but this should be done so as both the student and MEI are very clear about what is taking place. It should be briefed and done at altitude with a contingency plan if things don't go as planned. Simulating an engine failure by any other means than pulling a throttle to a zero thrust setting is crazy and wouldn't take place in my cockpit.
Chris
Your post is somewhat contradictory. On one hand, you say you understand the need to feather an engine and restart it, but on the other you say that the only way of simulating an engine failure should be to retard the throttle.
There is no better way to simulate a real engine failure than by turning off the fuel on an engine. The student doesn't suspect it, and as long as the weather conditions are conducive to keeping the aircraft aloft on one engine and there is an airport nearby, I see it as a non-event really.
Even if the good engine were to fail, there should be plenty of altitude to restart the engine with the fuel cutoff. If not, you can still do what all of us single engine guys do and put it down in a field.
Just so you know as well, I have ran this procedure by 3 DPEs that we use. Two are retired Army pilots, one of which retired from American, as well. The other is retired FAA. All 3 of them do the same thing to simulate a failure at altitude.
