Houston
Yeah, I was taught that when I was doing instrument training in the RJ.
,... you believe that every ILS has a MM located at the MAP do you?
You got a cite for where the Instrument Flying Handbook says that you should start time on an ILS approach in case the GS goes out? I cruised through it to the places where I figured such information would be, but I can't quite find it.
EDIT: And while I was looking through the IFH, I found another way you could identify where the MAP is; the marker.
This is one of those things where you need (a little) experience. If you seriously can't tell when you cross a navigation antenna, then I have nothing more to say aside from suggesting that you go find a CFI and practice your VOR/LOC skills.
Sent from my Galaxy Nexus that ate your iPhone.
Are you under the impression that I wrote there was or wasn't a specific citation in the IFH?
Just a couple miles past, assuming you knew when you passed the antenna. You might want to submit that as a suggested change to the Instrument Flying Handbook. I'm sure your idea would be viewed with great interest.
I think it was you that gave the impression that it's in the IFH.
Which I took to mean that, since we're talking about timing on an ILS approach, that since you believe waiting for station passage is a bad idea in your mind, that your alternative, timing, is in there.
Negative on your first sentence. If I did, it was a failure on my part to be clear in my writing.
On your second sentence, all I've done is to ask questions. I have not advanced an opinion or belief one way or the other on anything. However, I'd be happy to do so if anyone was interested.
Sure, let's hear it.
I don't think what you're saying is unreasonable, but I do think it's overkill.
For what you're describing, I get it. In fact I lived it at one point in my life. I did my instrument training in a beat up 172 where we had to do partial panel, full procedure NDB approach's (in VMC, of course) because more often than not, the ADI decided it was time to stop functioning and, well, there was no radar where I trained, so we did everything full procedure. So timing approaches? Yeah, I appreciate it. And when I worked at the freight company with no GPS, of course we were timing things.
But for modern glass cockpit ops? I think it's overkill. Add in some performance where you can out climb almost any obstacle if you lose guidance within the marker? Overkill without a doubt.
So you could argue that it should be carried over to other ops, but that's where I disagree. I think it sets you up for the mindset that you should continue an approach when going missed is the better option (and I'll also add, I WAS taught to time the ILS so that you could revert back to the LOC approach if necessary, and I think it's a bad procedure). So I don't view it as an extra degree of security, at least for the operations that I'm doing, it's an extra degree of liability, because it makes you think, "Oh, well if we lose the GS, we'll just continue the approach using this timer here" when our FOM says to just go around.
Or maybe said another way; opportunity (timing an approach where it's not necessary) is the mother of all screw ups (as it makes you think that you are doing the right thing by pressing things further than you should).
Now would most my co-workers do that? No, but then again, I haven't seen somebody time an approach in ages.
