Yes, they do have one and I do use it. However, I find a few strange things about the setup in the site. As for one, I was taking a test and I came across a Multi-engine question. I am not taking the MEI so why did this question come up? Is the Multi portion of the test required to know for the initial CFI?I think www.exams4pilots.com has one. Unfortunately, I'm being WAY too lazy to go look right now.
You might run into gyroplane questions too, remember you're taking the written for CFI-A(irplane). The MEI does not require a written so since they only have one shot at your knowledge base they will test you on everything under the sun.Yes, they do have one and I do use it. However, I find a few strange things about the setup in the site. As for one, I was taking a test and I came across a Multi-engine question. I am not taking the MEI so why did this question come up? Is the Multi portion of the test required to know for the initial CFI?
I am pretty sure there are like 10-20 Multi Q's in the bank due to what the previous poster said.You might run into gyroplane questions too, remember you're taking the written for CFI-A(irplane). The MEI does not require a written so since they only have one shot at your knowledge base they will test you on everything under the sun.
That's what I was eluding too.I am pretty sure there are like 10-20 Multi Q's in the bank due to what the previous poster said.
