tgrayson
Lift is proportional to Cl and airspeed,
Cl is linear with AoA for conventional airfoils within the non-stalling range of values.
Nice try.
Exactly... but not after that. Lift decreases dramatically beyond the critical angle of attack. So it is pointless to teach something that is incorrect for the sake of simplification. The equation is not L=1/2p*s*AOA*V2, it is L=1/2p*s*Cl*V2. It is written that way for a reason. The only thing you do when you teach something incorrect the first time is ingrain it in someone's brain and it has to be "untaught" later on. Frankly, if you said something like what you originally wrote on a CFI checkride you would probably bust.Cl is linear with AoA for conventional airfoils within the non-stalling range of values.
Nice try.![]()
Funny... I don't remember writing anything about throttle, yoke, or any of that. We were talking about your statement thatIf you think you're making a point, you're not.
Teaching that the throttle is the primary control for airspeed and the yoke is primary for altitude isn't a simplification, it's wrong, and will lead to wrong control inputs in some situations. The argument that it's a "simplification", and therefore a benefit to the student, is to me an excuse for an instructor not to expend the effort to achieve the correct understanding. In other words, it benefits the instructor, rather than the student.
How do you increase/decrease your AOA without also increasing/decreasing Pitch attitude at the same time? [conventional fixed-wing aircraft]
There is no question that I’m moving towards a single-pilot certified jet and I don’t want to carry any bad habits into that level of flying. Piloting covers many subjects and this is just one of the embedded subjects. Pitch/Power/Trim seems to develop some controversy among some, but my goal is to be efficient and optimize everything I do. That’s why I bring it up and that’s why I seek your opinions. There is a ton of myth, rumor, speculation and innuendo out there when it comes to what an aircraft will or won’t do, can or can’t do. That’s why I need to make sure that I’m always dealing in the reality of flying, not the hype.
I have flown helicopters, jets, turbo props and "small" airplanes. The concept of flying seat of the pants applies to all. You learn your pitch and power settings, and confirm what you see outside with the instruments. There have been a number of crashes where pilots of large jets flew them into the ocean on a clear day or night, just because the instruments where not telling the truth. In the two I can think of off hand static ports where taped up for an aircraft wash. Absolutely insane that pilots would ignore what they see outside and fumble with instruments that are not telling them the truth.Thanks.
[I’ll standby for any specific replies from my above questions – if you deem it necessary]
Not at all. I think much of what you wrote has helped the OP. I guess you can read minds, however. My point is that you wrote something that was incorrect and should not be read by a student pilot without being corrected. Lift does NOT=1/2p*s*AOA*V2, and for a student pilot to be taught this is not only wrong, but very dangerous.No, you're using that a red herring. You're arguing in bad faith and I won't participate.
I
Very interesting, indeed. Does anyone here disagree with this in anyway. Or, have any modification to it?
It seems so simple and so straight forward. However, you covered the descent from unaccelerated straight/level flight. You did not however, cover the climb from unaccelerated straight/level flight. Is it therefore correct to apply the same principle to initiate the climb?
Example: Increase throttle [from hands-off unaccelerated straight/level flight], nose rises [aerodynamic properties of the aircraft], climb to desired altitude, decrease throttle to level off, fly on to your next decision. Do I have that about right?
Ok, now that logically made sense, but then my "intuition" kicked in and my brain started throwing me yellow caution lights as I read through what you wrote. Help me out here for just a minute: Would this not be a rather difficult task?
First, you say trim for an airspeed. Assuming for a moment that we are just talking about basic climbs and descents (no turning climbs or turning descents), won't this be rather difficult to accomplish with higher airspeeds, given the aerodynamic forces on the trim-controls? At lower airspeeds, won't the trim-control force required to move the surfaces be significantly smaller and at higher airspeeds, significantly larger?
And, won't that gradient of trim-control force required as you move from high airspeeds to lower airspeeds, cause problems with "handling consistency" in maneuvering the aircraft with precision most of the time? I'm just trying to think this all the way through. Certainly, something I could test, with an IP in the right seat, no doubt.
Are they still equal and acceptable if the force required to trim-to a particular airspeed is greater at higher airspeeds?
Example 1: I trim to 105 kts from 85 kts in a 172, then POWER to a 300 fpm climb by adding 300 bars on the tac according to Mshunter.
Example 2: I trim to 350 kts from 250 kts in jet, then POWER to a 3,000 fpm climb by adding the equivalent shaft rpm to the turbines according to Mshunter.
First, how can you trim to 105 and 350 from 85 and 250 respectively, without trimming down the nose to build-up airspeed? Then, turn right around and put-on more power [either bars or shaft] to establish a rate of descent. Does this mean that the aircraft goes down first in order to go up? [/FONT]
What about the inverse. First, I trim-up the nose to reduce speed from 105 and 350 down to 85 and 250 respectively. Then, I take-off some power [either bars or shaft] to establish a rate of descent. Does this mean that the aircraft goes up first in order to go down?
Wrong? Yes, in a purely technical sense.
Very dangerous? How so?
Yeah, andYou get low and slow on final, and the person who thinks the yoke controls altitude will mush the airplane into the ground, or stall it.
You get low and slow on final, and the person who thinks the yoke controls airspeed will push the nose over and slam nose first into the ground.
add power to return to a proper flying airspeed while they use pitch to maintain an appropriate glide path.
Wrong in an application sense as well.
Aircraft don't generally crash due to a lack of lift, they crash due to too much drag. Even after the stall, you will generally have lift=weight or pretty close to it; some of the weight is supported by drag. With a sufficient amount of power, you could fly with both wings stalled, if you could maintain directional control.
Pilots, in general, shouldn't concern themselves with lift, because the natural stability of the airplane will ensure that lift=weight. Mostly what they need is more thrust and less drag.
Wrong in an application sense as well. If an airfoil is stalled and you attempt to increase the lift on that airfoil by increasing the AOA, you will be in for a surprise- such as trying to lift a wing that is dropping in a power on stall with aileron.
It is dangerous because it teaches a student the false information that increasing their AOA should increase lift. Are you saying this is NOT dangerous?? If a pilot is in a stall and the ground is rushing up, they should just pull back harder on the yoke and increase the AOA to increase lift and stop the descent?? Not that there has EVER been an accident where this has happened.![]()
Not many pilots are pondering the lift equation when recovering from a stall. They're just going through physical motions as taught to them previously.
In all honesty, I teach the lift equation using AoA instead of Cl because AoA seems easier to visualize and remember than Cl for most people. However, I always preface it by saying this equation only works up to the point of stalling. That gets most people through their private license just fine.
When talking about stalls, I make sure they understand a few key points:
Stalls come from exceeding the critical AoA, regardless of speed or pitch attitude
When a wing stalls there is a sharp increase in drag and decrease in lift
For most people, I don't go in to the math behind it, but I haven't noticed any major problems. If they understand those two concepts they can handle spins and inadvertent stalls fine.
I have to LOL at the JKD standing wrist lock. Good luck against a resisting opponent. I prefer a Seoinage, Harai Goshi, or Kosoto Gari after closing the distance.
Not possible, unless you have a stall speed of zero. But PE will be zero and that makes the ratio undefined.
The limit, of course, as PE trends toward zero will be infinity.
Really??? Which aerodynamics book did you read this in??? Lift is proportional to Cl and airspeed, not AOA and airspeed. I know it seems convenient to simplify things by equating an increase in lift to an increase in AOA, but you do a dis-service to teaching someone if you teach them something that is not true. I have had more than one CFI applicant spout this nonsense due to the law of primacy.
Exactly... but not after that. Lift decreases dramatically beyond the critical angle of attack.....
... As a matter of fact, at the bottom of a loop my nose and wings are pointed down, I am going at least 120 MPH and I am riding the edge of a stall.
...Absolutely insane that pilots would ignore what they see outside and fumble with instruments that are not telling them the truth.
Again, why teach them something that is incorrect or half true??
I have not had ANY problems with student pilots understanding Cl. I don't expect pilots to ponder the lift equation as they enter a stall, but understanding the actual equation can make them understand the influence it has on performance.
They suddenly understand why DA is important (1/2p).
They understand that on most airplanes they primarily have two ways of changing Cl- primarily through pitch, but also through flaps on some airplanes (may also change S).
