but yet the 737 behind you still had to slow to final approach speed 10 miles out
I fly my airplane, you fly yours.
Because final approach speed in the 73 is like 290but yet the 737 behind you still had to slow to final approach speed 10 miles out
It is the fastest slow airplane I’ve ever flown.Because final approach speed in the 73 is like 290
Flaps 15 with a full 15 knot additive the other night when it was all gusty and crosswindy in SFO… we went to plaidIt is the fastest slow airplane I’ve ever flown.
When I commuted I never brought it up or put extra pressure on the other pilot. I chose to commute. Your cake is already baked once you takeoff and there’s not much you can do other than F something up by trying to rush the entire flight playing some self imposed game. I also don’t do “go home leg” games. The paperwork will take longer than the time saved. That’s my .02 on the subject from 20+ years of doing this.
Dayum! What was the cause for the flaps 15?Flaps 15 with a full 15 knot additive the other night when it was all gusty and crosswindy in SFO… we went to plaid
Seemed appropriate for the weather conditions.Dayum! What was the cause for the flaps 15?
Seems that at some Guppy shops they can do normal flap 15 approaches.Dayum! What was the cause for the flaps 15?
“We’ll write it up when we get back to base.”When I commuted I never brought it up or put extra pressure on the other pilot. I chose to commute. Your cake is already baked once you takeoff and there’s not much you can do other than F something up by trying to rush the entire flight playing some self imposed game. I also don’t do “go home leg” games. The paperwork will take longer than the time saved. That’s my .02 on the subject from 20+ years of doing this.
This is not a critique of your flying ability/technique.I fly my airplane, you fly yours.
“We’ll write it up when we get back to base.”![]()
I had no idea. At my shop flaps 15 is a non-normal only flap setting.
Yeah. Normal landing, if needed. Our small landing card books have final ref numbers for 0, 1, 5, 15, 25, 30, and 40, for any given weight; and 15 and better is considered normal.
Thanks! Learning has occurred. 30 and 40 are the ONLY normal flap settings where I’m at so it’s really cool to learn how everyone else does it.Flaps 15 is a normal landing at SJI in the Guppy. Only pilot I know that does them regularly outside of CQ also calculates the fuel burn after landing to see if he saved gas for his profit sharing check.
Essentially it’s given to us as a tool in windy or gusty conditions where Vref plus wind additive is at or very near to flap limit speeds as flaps 15 had a greater range between base Vref and limit speed and therefore a bigger margin to prevent over speed.
It leads to other considerations in terms of brake cooling and runway length and personally don’t find much need for flap 15 landings and honestly find them less pleasant for those in the back so I generally avoid them. The 900ERs and 800s with the SFP usually have enough gap in speeds that a normal flaps 30 landing still leads to a good margin even with Vref+15. The base 800s though can get close though, especially at higher weights or if you’re carrying extra fuel for an alternate.
I just assumed they got blown-back to 15 and then tripped the lockout when jiggling the handle between 15 and 25.Dayum! What was the cause for the flaps 15?
