NASA drops Cessna for science
In a recent incident I am familiar with the ELT did not go off as it was destroyed on impact. I think in a lot of cases the ELT is only going to be helpful when the crash is survivable...
The Ted Stevens crash was survivable but the elt was either damaged or just separated from its antenna.
True, but the people looking for you probably feel differently.
Congressman Hale Boggs comes to mind. The Air Force reportedly even resorted to using an SR-71 in the search for that C310.
Still missing to this day, almost 43 years later.
Forgive my ignorance, but at what point does the 406Mhz ELT become mandatory?
Doesn't matter unless they really crack down on mounting and installation. Shoot most of them the g switch won't even work unless the cannon plug to the remote switch is plugged in. 406 elts are an ok idea but the execution has been completely bungled imho.
I like the word "bungled" it makes me happy for no apparent reason. If a connector isn't connected it won't connect. Why aren't the connectors connected?
G-switch should still work as long as the ELT is armed... The remote switch isn't even mandatory is it?
Connectors tend to come disconnected when airplanes impact terrain. Especially problematic with the antenna cable.
It's been a while because we have our local avionics guy do our 406s but I seem to recall that with most of them unless the cannon plug is in you can't just whack them on the bench and use a stereo even for the 121.5 portion. I think at least for the Artex ones you have to have the remote switch as that is one way you do the self test on it.
I have found the Spot Connect to be handy for flight tracking and being able to send customs messages from remote locations.
Don't laugh. When I was in the lab, most of my "discovery moments" were "Hrmph...that looks weird" or "Why the F is it doing that? I'm sure that was clean glassware" moments versus "eureka!"
Then you'd look back in your notebook and see what you f'ed up so you could do it again.
Far more advancements come that way versus the carefully planed experiments. Everyone loves to draw a line or curve between two points and say "whoop, that's the way the world works", but that ain't the truth. In reality, nature is full of discontinuities and asymptotic lines, and that's where all the REALLY interesting stuff happens.
Richman
